AC slowly dying
I just picked up a 40k mile 2000 AP1 and noticed a few things after a couple days of driving. My AC is cool when moving, but warm at idle. It seems to be getting worse the more I go out. I dont see any obvious leaks, and the ac condenser fan is spinning, which I thought it might be. Could it just need a top off of freon or could the condenser fan be dying? TIA
You can get a harbor freight gauge for like $70, that and a vacuum pump for roughly the same price, is all you need to service the ac system.
Get a manifold gauge set and check the pressure. Check that the condenser isn't clogged with dirt and debris. If enough dirt accumulates on it, it can affect cooling at idle. Also look at the subframe near the compressor, do you see any oily substance there?
It turns out my compressor is weak. As soon as its given revs the low side pressure drops dramatically and cools the cabin. What else should I replace other than the compressor and drier?
If you want something to replace, the expansion valve. You have to remove the battery to do so. There's a 4mm allen bolt that'll likely be on really tight holding it on.
Unfortunately I dont remeber, but I remember the number being static, even with revs. The dryer sounds right, I'm not sure if this is related, or just because I live in florida, but since it does act as a moisture filter if it were clogged would my air feel humid? It almost feels like it leaves my steering wheels wet when the air is blowing on it.
