AC slowly dying
Old Feb 5, 2023 | 03:13 AM
Slowcrash_101's Avatar
Originally Posted by FeefTheSloth
Unfortunately I dont remeber, but I remember the number being static, even with revs. The dryer sounds right, I'm not sure if this is related, or just because I live in florida, but since it does act as a moisture filter if it were clogged would my air feel humid? It almost feels like it leaves my steering wheels wet when the air is blowing on it.
Yep, if the high side isn't moving then there's a restriction, or you have air/ moisture in the system.
Old Mar 6, 2023 | 11:34 PM
FeefTheSloth's Avatar
As it turns out, the compressor is just weak. Im honestly surprised that at 40k miles its out of juice. the Dryer helped a little but not enough for the heat of florida summers.
Old Mar 7, 2023 | 02:30 AM
It's all in how you charge the system. If there's air in the system it'll make the compressor seem weak. I have a used compressor in my car and the AC blows nice and cold. Im in FL as well.
Old Apr 4, 2023 | 12:58 PM
Speaking of charging the system, I just replaced the compressor and filled it up to the proper psi, but im not getting cold air at all. not when moving or at idle. I think I have a blockage in the system because I put barely any refrigerant in and it already reads correct psi. Not sure what to turn to next...
Old Apr 5, 2023 | 02:15 AM
You can't rely on low side pressure, you charge the system by weight, not pressure.
Did you vacuum the system of air?
HappyFunNiceGuy
Jun 23, 2025 06:22 AM
nicksain
Jul 17, 2008 07:46 PM
Hoa
39
Dec 9, 2007 05:41 PM
plankfarm
38
Aug 11, 2006 03:32 PM
HondaGal
Nov 12, 2005 02:59 PM
