Access to Differential Fill Bolt to Torque
Old Apr 30, 2016 | 06:13 PM
khangaroo's Avatar
Default Access to Differential Fill Bolt to Torque
Does anybody have any trouble with using a torque wrench with a regular socket on the differential fill bolt? It's easy to remove the bolt with a box end wrench but then my torque wrench doesn't fit with a regular socket. I ordered a low profile 24 mm 3/8" drive socket from O'Reilley so I'm hoping that will let me fit in.
What do you guys do? I was thinking of just foregoing proper torque and just retighten the bolt with the box end but I would really like to have it properly torqued.
Old Apr 30, 2016 | 06:24 PM
afzan's Avatar
I think most people use a wrench
Old Apr 30, 2016 | 08:08 PM
cosmomiller's Avatar
Top Answer: 1
You can use an open ended wrench that will fit easily. You can get pretty close to a torque value if you practice. Use new crush washer; it helps.
Old Apr 30, 2016 | 11:12 PM
Soviet's Avatar
This.
Old May 1, 2016 | 01:57 AM
Slowcrash_101's Avatar
Crows foot wrench will work with a tq wrench.
Old May 1, 2016 | 05:44 AM
cdubea's Avatar
By doing this the torque is NOT going to be what the wrench is reading.
Torque = Force times distance
You have changed the distance. How do you calibrate for the what you added?
Just do like the others have said, use a new crush washer and a box wrench.
Old May 1, 2016 | 05:53 AM
Depends how you do it.
Old May 1, 2016 | 06:01 AM
trapper's Avatar
Originally Posted by Soviet
This.
Old May 1, 2016 | 06:14 AM
windhund116's Avatar
I like to use the boxed end of a combo end wrench. To avoid rounding the nut's edges. Rubber mallet as gentle persuasion.
https://images.jet.com/md5/303a22ac8...74a7aae07.1500
Old May 1, 2016 | 06:28 AM
Car Analogy's Avatar
Definitly true. But you'd probably be closer to correct torque than if you just go by feel. Not that doing good n tight will cause a real problem, but crowsfoot on a torque wrench is certainly acceptable alternative.
You could always just reduce wrench setting 5% or something to compensate for the length difference.
Sent from my SM-G920P using IB AutoGroup
