Access to Differential Fill Bolt to Torque
Old Jul 1, 2017 | 04:52 AM
  #31
windhund116's Avatar
Wow, to R&R the gears and cost of that rear case... muy $$$ fix. No?
Old Jul 1, 2017 | 05:29 AM
  #32
rpg51's Avatar
Next time I pull my fill bolt I am going to have to take a very close look. I think its ok - but I did feel something I did not like last time I snugged it up. It is snug though. So, maybe its ok. Another thing to keep me up at night.
Old Jul 6, 2017 | 11:55 AM
  #33
cruc1a7's Avatar
Nah, All you gotta do is pop the shaft assemblies out and the rear housing unbolts from the rest of the carrier.
Old Jul 6, 2017 | 12:57 PM
  #34
Chuck S's Avatar
Crowfoot wrench on your torque wrench will properly torque the differential fill bolt.
-- Chuck
Old Jul 6, 2017 | 10:12 PM
  #35
nicostatus's Avatar
Random point, I just did this with a crowsfoot wrench and it worked great. I also replaced the fill bolt with another OEM magnetized drain bolt, so now it has dual magnets. I just never understood why they'd make each bolt a different wrench/socket size. More of an ease of use thing.
Old Jul 7, 2017 | 11:40 AM
  #36
Jah2000's Avatar
Crowfoot extensions seem pretty accurate...
Old Oct 8, 2017 | 02:23 PM
  #37
SKKYI's Avatar
I just replaced the rear diff fluid (2001 Berlina Black 26K miles). used 23 mm combo wrench to remove the fill bolt, then used 15/16 6pt socket with 3/8 drive torque wrench to torque to 33 Lb Ft. be sure to use 6pt 15/16 socket not 12 pt. 12 pt socket might round. if you have 23mm low profile 3/8 drive socket, it will work also.
13darkknight
Sep 19, 2010 06:39 AM
sscott0203
May 30, 2010 10:33 AM
hariku821
Oct 20, 2008 01:02 PM
Bret
Dec 10, 2003 07:43 AM
