adjusting my Tein coilovers
Old Mar 29, 2007 | 11:00 PM
white2k's Avatar
Default adjusting my Tein coilovers
I bought my S2000 used, so it had Tein coilovers on it , I noticed that the front is higher than the rear, which isn't normal? Also, i would like to go lower too. So, I was wondering how would I be able to adjust it properly to the ride height I want?
Thanks
Old Mar 30, 2007 | 06:55 AM
GPS2K01's Avatar
I'm not sure if this will help but I measured each assembly before I installed to make sure they were at manufacturer's spec which is 1" drop on the Tein Flex. If you get on their website-there is a PDF of the manual/instructions that gives the measurements. There is also a very nice write up in the DIY section that has the link for the manual.
Old Mar 30, 2007 | 09:31 AM
littlerocket777's Avatar
When you say the front is higher than the rear, are you just measuring the wheel gap or the height of the wheel well to the floor? If so, all cars have a higher wheel height in the front to factor in for a car turning.
Old Mar 30, 2007 | 09:45 AM
white2k's Avatar
Just noticing from the wheel gap..
didn't really measure it
whomikedao
Nov 20, 2014 01:32 AM
Luis06s2k
Jul 5, 2011 08:13 AM
HKSSupra91
May 29, 2007 10:58 AM
Wongawa
Aug 8, 2003 09:06 AM
