Adjusting rear camber
Old Sep 14, 2005 | 02:35 AM
solomon's Avatar
Default Adjusting rear camber
Is the rear camber adjustable, and if so how do you adjust it? I just installed Tein S-Tech springs on my MY05 and want to adjust the rear camber back to stock specifications. Thanks for any and all advice.
Old Sep 14, 2005 | 07:03 AM
FO2K's Avatar
Take it to a good alignment shop.
Old Sep 14, 2005 | 10:22 AM
steven975's Avatar
yea, most shops say it can't be done, because their 1-week training class says that hondas are not adjustable, so it gets ingrained in their heads. They'll argue it, too.
Old Sep 15, 2005 | 02:42 AM
solomon's Avatar
No, what I mean is, is there a component in the rear suspension that allows for adjustment of the rear camber? On my last car, an 04 Accord Coupe, I had to purchase adjustable camber arms from SPC because there was NO WAY to adjust the camber without them. I had read a post on this forum somewhere that said that camber adjusting equipment was not required because the S2K's rear camber could be adjusted. What I need know is, if the rear camber is adjustable from the factory, how is it done? Thanks for any and all replys.
Old Sep 15, 2005 | 02:44 AM
jzz30's Avatar
if its adjustable usually its doen with an arm bolt which is a cam. usually the lower arm bolt is like this, and there is a dial on it.
Old Jan 17, 2006 | 11:02 AM
peteriap's Avatar
Just saw this and thought I would reply. The factory camber is adjustable but only to an extent. SPC does have front and rear kits available for our vehicles. I have them on the front of my04 and they work great. You can find them at www.camberkit.com I didn't use them on the rear and the rear tires seemed to wear very evenly. Just make sure to get a good 4 wheel alignment at a reputable shop. Hope this helps even though it has been a while.
Apex1.0
Aug 23, 2014 08:57 AM
DeletedUser05.22.20
Jun 27, 2014 03:59 PM
cookies28
Jun 21, 2012 08:14 PM
JVS2
May 26, 2009 10:02 PM
r8byb
Mar 17, 2009 11:00 AM
