AEM EMS : NA Map needed.
Old May 12, 2008 | 04:25 AM
Bibbs's Avatar
Default AEM EMS : NA Map needed.
Can anyone help please?
I've just swapped engines (old one blew a bottom end) and no longer have an SC on the car.
I've not got the stock injectors etc. so need an NA map for my car.
F20C, 750cc RC's, de-cat and single exit.
Just looking for something to get her started and running.
The SC map is obviously too rich under throttle.
If someone could mail me at:
<removed>
It would be appreciated.
(I've tried to one of the AEM forum and it didn't idle well at all).
Old May 12, 2008 | 04:29 AM
fltsfshr's Avatar
aem s2000 website
here ya go
fltsfshr
Old May 12, 2008 | 04:35 AM
Bibbs's Avatar
Been on there too.
I couldn't get the 1.11 working (I've a 1.19, and it wouldn't fire).
The other base map on there would just about idle, but as soon as the throttle was pressed and eased off, it'd stall the car.
Old May 12, 2008 | 01:40 PM
AusS2000's Avatar
Firstly, if your SC map is based on load it should be fine. It's just the same except you're running only in the bottom area of your fuel map.
Otherwise you need to install the 1.19 and run the fuel injector wizard to let it know you have 750cc injectors.
Old May 12, 2008 | 11:48 PM
Bibbs's Avatar
Cheers Aus.
That's what I did. I think the SC map is still too rich below 0 PSIg.
I used the std 1052.1.19V map (with the injectors changed). And the car sounded awful.
Can I just set the o2 feedback going and drive round the block?
Old May 13, 2008 | 05:02 AM
camuman's Avatar
Originally Posted by Bibbs,May 13 2008, 02:48 AM
Cheers Aus.
the map is based on pressure, but negative and positive. what your saying makes no sense. use the same map you had when you were boosted, because you will never hit the boost part of the map, so car will be the same.
Old May 13, 2008 | 06:29 AM
Bibbs's Avatar
I always thought you'd run a FI'ed car richer (about 1 point on the AFR) than an NA for the same inputs.
But that could be me just getting confused about NA maps never seeing +ive boost as you say.
It's been a long few months of getting the engine swapped out, and I just wanna drop the roof down and drive.
rikhemi
Mar 16, 2014 06:15 PM
Wydget
Nov 26, 2012 06:48 PM
TerminatioN
Mar 7, 2012 04:37 AM
AP2000
May 13, 2010 05:49 AM
CourageOO7
Nov 25, 2007 08:26 AM
