AEM Engine Management System (Q & A)
Old Mar 7, 2004 | 10:04 AM
  #131
beroznikmal's Avatar
try and pm wicky or turbo_pwr....they both have NA setups....
Old Mar 7, 2004 | 01:16 PM
  #132
AndyDoh's Avatar
Try Hans for N/A AEM map's & why is Ardy in the penalty box?!??! whats he done?
Andy
Old Mar 7, 2004 | 02:04 PM
  #133
Slows2k's Avatar
I don't know what happened with Ardy, I just noticed "in the penalty box" on his posts.
Old Mar 7, 2004 | 02:13 PM
  #134
Ardy emailed me a week back and he mentioned that he was banded from s2ki.... I have his email address if you guys are interested...
Beroz
Old Mar 7, 2004 | 04:18 PM
  #135
FF2Skip's Avatar
[QUOTE]Originally posted by mxt_77
Any dyno results from a tuned AEM EMS on an NA car?
Old Jul 14, 2004 | 12:28 AM
  #136
debos2k03's Avatar
Horsepowerfreak,
i was needing some help with knowing what to get if im going to try and put more boost on my sc S running about 9 psi to make it run right with the aem ems unit. i dont want to get somethign that i want use or forget somethign that i need.
Old Sep 17, 2004 | 12:53 AM
  #137
timg's Avatar
Chris and Sean,
I'm not sure if you're still following this thread or not- my e-mail notification seems to have stopped working on here. A month ago, I bought a 30-1012 ECU, AEM WB02, 650cc injectors, Fidanza flywheel, SPEC clutch, VTECFrog harness, and GM boost control solenoid from you. The salesman was Ron Wyman for most of it, though I did purchase some from online.
I saw that you said that you typically provide base maps with ECU purchase. I'm hoping to get a base map for my car + turbo. I have it tuned and running VERY well right now(stock 2004 + WBO2 - not looking for any help here), but I'll soon be running a GT30R turbo(plumbed exactly the same way as the turbo at the start of this thread) with 650cc injectors. I'm hoping for a map that will give me a good place to start for ignition timing and fueling with the turbo. I will be doing some more tuning on a stock motor with the 650cc's before the turbo. I have considered using Sean to tune it, but I would like to hold off until I have tried my best(and I do have some previous experience). Thanks.
Tim Grady
Pics of some of the parts
https://www.s2ki.com/forums/index.php?showtopic=213592
Old Sep 17, 2004 | 06:28 AM
  #138
Ztec's Avatar
Great thread - I hope it continues!!!!!
Old Jan 23, 2005 | 09:12 PM
  #139
Mr. Tom's Avatar
Ok, now im going to ask my questions. Is there a base map for a vortech supercharged s2k? I only ask because there are basemaps for other hondas with SC's.
That being said, How would i best go about changing the base map (1012 v1.11) to run with a vortech and 650cc injectors? (the map I already have obviously doesnt work properly) I dont need power, or even economy, I only need to get the car safely to the tuner (50 or so miles away)
As of right now, the car turns on, runs very rough, then dies. if you give it some gas, it stays running, but sounds really bad. my untrained ear tells me it sounds like the timing is WAY off, but thats just a shot in the dark, right now im just guessing.
Old Jan 23, 2005 | 10:46 PM
  #140
Mad_Paradox's Avatar
Nice numbers and good job on the interior fabrications, very original.
I think this thread should be put into the FI forum as it does refer to some good technical info.
