aem v2 intake
Old May 3, 2007 | 11:04 PM
J's_Racer's Avatar
Default aem v2 intake
i just bought a car with it and the seller doesn't have a stock air intake for it. should i be worried? (KS rains quite a lot) , and if i were to downgrade which will be better?
PM me if anyone wants to trade
Old May 4, 2007 | 02:43 AM
J's_Racer's Avatar
any feedback guys? i dont want to hydrolock my engine =\ on my 1st s2k
Old May 4, 2007 | 03:48 AM
twisted1's Avatar
I have the same exact situation...
Funny the angled it up not down to drain the water out...
Took the filter off and run it under the faucet to see if water gets in easily... well YES it does... runs right through...
There is a little rubber plug with a little slit in it at the base of the pipe .
Kinda whistles at certain throttle amounts too...
Anyways.. I'm just thinking that the pipe is soooo long that any large amounts of water to hydrolock is probably not going to happen...
I'm thinking of putting a slightly oiled foam sock around it..
or maybe a K&N (it has a 3 1/2 inch opening.)
AND before anyone flames me about oil and the O2sensor... look in your throttlebody to see just how muck oil gets in there from the PCV valve.
Twisted1
Old May 4, 2007 | 07:41 AM
J's_Racer's Avatar
should i get it changed then?
Old May 4, 2007 | 07:55 AM
VAD's Avatar
VAD
dude your screen name totally threw me off....
https://www.s2ki.com/forums/index.php?showuser=58213
Old May 4, 2007 | 10:38 AM
importkid's Avatar
There is a DIY on how to plug the drain hole from under the hood. That is probably your biggest concern if you can avoid puddles.
Old May 4, 2007 | 12:04 PM
J's_Racer's Avatar
hmm alrighty guys i'll just look into changing it to other intakes..... since the intake sits so low on the ground
Old May 4, 2007 | 12:32 PM
RACER's Avatar
Originally Posted by J's_Racing,May 4 2007, 03:43 AM
I dont want to hydrolock my engine =\ on my 1st s2k
If you go through a fat puddle with the AEM, you'll be on your 2nd S2k
Old May 4, 2007 | 02:26 PM
neveronlines2k's Avatar
^ or 1st S2K with a 2nd motor
Old May 4, 2007 | 10:29 PM
J's_Racer's Avatar
oh shoot , i wonder what the previous owner did run through water or not
hmm if i have 240 245 239 240 comp on a 62k miles motor is fine right?
*sweat* since when my nick name changed ?!?!
so what is a good intake to consider at the same price range? i'd take out this intake then , can't justify 3hp increase over a motor replacement
