After replacing driver's side window...
Old Sep 19, 2008 | 09:38 PM
HGL1668's Avatar
Default After replacing driver's side window...
Recently, I just replaced my driver's side window because some hater through a rock at it and it shattered. I got replaced it with OEM parts and window.
Everything looks great but now, when I roll down my window, it makes a very noticeable "hit" when it reaches the bottom.
I asked the body shop who did the work to adjust it and they said there is not adjustments for it, but they were nice enough to try again but it did not work.
Is there padding under that window which might be missing? Or there is a way to adjust the amount it rolls down?
Thank you
Hugo
Old Sep 19, 2008 | 09:51 PM
s2k dre's Avatar
there should be rubber moldings inside the tracks on both sides, and that might be the problem if they fell out. I would take a look at the pass side and compare.
Old Sep 19, 2008 | 10:34 PM
tekstar's Avatar
was this in davis? hugo?
Old Sep 19, 2008 | 11:08 PM
AlX Boi's Avatar
A friend of my roommate came to visit Davis a while ago only to get a rock bashed into his BMW's rear window at Sudwerks.
Old Sep 20, 2008 | 01:52 AM
HGL1668's Avatar
2k dre, Thanks, I think that's what causing the problem since there is also scratchy noise when rolling down the window. Do I have to buy the rubber part or it is there already that I just need to fix it?
Tekstar, No, it happened in a nice Socal area. Apparently, not so safe, but I think I just got unlucky.
Old Sep 20, 2008 | 05:54 AM
roflitzjinno's Avatar
nothing is ever "normal" again when something gets replaced in the car, but if it makes it any better i noticed this in a few cars. seems normal to me. i wouldnt be too worried. if the window isnt shattering when it goes down and makes that noise it should be fine. if theres no damage to the window when going down it should be fine too.
Old Sep 20, 2008 | 01:34 PM
Mrfixit687's Avatar
Wrong, other than something very extreme; if you replaced something on your car and you know what you're doing and have the right parts it will be "normal".
Old Sep 30, 2008 | 12:56 AM
RydinRuff's Avatar
when the window is completely down and you go over a alot of bumps... like a cobblestone street for example? do you hear a clinking sound because I too have that problem
Old Sep 30, 2008 | 02:23 AM
CoralDoc's Avatar
Sounds like it's time to pull the door panel and make sure the job was done correctly. The window should function "normally". I did a complete R&R of my driver's side door (bought a used door and swapped all of my components over to it), and I never had any issues. There ARE adjustments that need to be made to the track, top and bottom stops, so I suspect they were not done properly. Have a look at a Helm manual and you'll be able to do it yourself if you have even modest mechanical skills.
theSILVERone
Oct 3, 2007 09:11 PM
CrazyIvan
Aug 23, 2007 10:02 AM
cbb
Aug 5, 2002 04:55 PM
Atlmike
Oct 22, 2001 10:08 PM
bentrim
Jun 18, 2001 11:12 AM
