Airbox Modification Discussion
Old Jul 1, 2001 | 06:21 AM
  #31
Chui's Avatar
My take on the concept is that until I see thermocouple data I am not convinced. I don't know the temperature differentials to say what the car should or should not gain. I know the theory - I have a Master's Degree in Thermal Sciences and I develop engines for my salary.
What I DO KNOW: Your induction system can be tuned to form a standing wave that coincides with Intake Valve Opening. The theory is Helmholtz Resonance. Long induction system with large cross sectional diam and lower rpm performance boost. Shorter induction system with similar cross sectional diam and high rpm performance boost. Of course, the geometry must be optimized.
Now combine this with whatever temp gains [ie., reductions] it offers and one will see more bhp from your engine. My concern is what temperature drop do we actually see.
My $0.03
Old Jul 2, 2001 | 12:31 PM
  #32
xviper's Avatar
[QUOTE]Originally posted by ultimate lurker
[B]Some folks have run tests with the OBDII computer to see what intake charge temps look like under various conditions.
Old Jul 2, 2001 | 01:01 PM
  #33
cdelena's Avatar
[QUOTE]Originally posted by xviper
[B]
Where exactly is the IAT sensor?
Old Jul 2, 2001 | 02:26 PM
  #34
Gregg Lee's Avatar
Look at underside of the lid of the airbox and you will see that intake air flows through the duct formed in the lid. It does NOT flow through the bottom half of the filter box outside the baffle.
While you have the lid off, pour some water into the airbox bottom on the non-filter side of the baffle. It drains out the drain hole in the bottom.
With the lid back on the air filter box, feel inside the intake horn. The intake horn fits into the duct in the lid except for a gap in the bottom. The only reason I can think of for the gap is to try to dump rainwater sucked into the air horn before turns the corner to the filter. The baffle keeps the water from the filter until it drains.
[QUOTE]Originally posted by pfb
[B]Great discussion.
Any thoughts on the original intention of the internal baffle with the stock air box?
Old Jul 4, 2001 | 04:35 AM
  #35
s2ktaxi's Avatar
Old Jul 4, 2001 | 07:37 AM
  #36
cdelena's Avatar
[QUOTE]Originally posted by s2ktaxi
[B] There are actually two parts to the airbox that seem like unecessary appendeges or sections.
Old Jul 4, 2001 | 09:35 AM
  #37
s2ktaxi's Avatar
if you take a look at the cover of the airbox when you take it off, it seem like the air is funnelled straight into the main chamber - so I do not think that the first chamber is for water collection. I could be wrong.
I'll see if I can dig up the reference to the airbox being designed for sound reasons.
Old Jul 4, 2001 | 03:15 PM
  #38
2kturkey's Avatar
[QUOTE]Originally posted by Chui
[B]My take on the concept is that until I see thermocouple data I am not convinced.
Old Jul 5, 2001 | 08:38 AM
  #39
The Reverend's Avatar
I would imagine there is enough volume in the airbox that adding an extension to the stock airbox probably wont mess any resonance up too much as long as there is low restriction to the airbox opening so that the airbox can maintain a sufficient amount of air at the ready.
Old Jul 5, 2001 | 12:47 PM
  #40
xviper's Avatar
[B]if you take a look at the cover of the airbox when you take it off, it seem like the air is funnelled straight into the main chamber - so I do not think that the first chamber is for water collection.
