Airpump Delete, where is the Current Sensor?
Old Jan 26, 2013 | 04:25 PM
Cross's Avatar
Default Airpump Delete, where is the Current Sensor?
So I am removing the Airpump system from my 02 S2000 and installing Izze's delete.However I found everything but the Current Sensor.... where the hell is that thing? I came in to get the wiring instructions so I can finish the install but I cannot find the current sensor to pull it out as well. Hopefully I can get all the pieces together and put them up on eBay as they all worked I just frankly did not want them on the car if they could be deleted.
Is the Current Sensor not on all model's or is it located in the car or where the hell am I overlooking it?
Thanks guys
Picture of the item I'm looking for:
Old Jan 26, 2013 | 04:56 PM
_brandon's Avatar
The module is ment to piggy back off your ECU and work as if the air pump is plugged up. ECU is underneath the steering wheel to the left. If you check the website it shows the instructions. I installed mine in less then 30 minutes with the removal of air pump. Hope this answers your question. Follow the instructions CAREFULLY, you are doing something rather extreme that could cause problems with the "brain" if you do not follow to the T.
Old Jan 26, 2013 | 05:43 PM
Cross's Avatar
The install is no issue at all I am just trying to find the Current Sensor it shows a picture of in the install PDF. Let me see if I can find a copy of that picture.
Basically I want to ensure I got everything I do not need removed.
Old Jan 26, 2013 | 11:07 PM
_brandon's Avatar
Oh I see, I dont remember seeing it. I think its by the airpump itself, like nexxt to it. Not 100% because I think I didnt remove that part
Old Jan 27, 2013 | 01:22 AM
Cross's Avatar
I thought that too so I even tried finding pictures of people with their front bumper off and I did not see it... I am starting to think I am overlooking it or its just not on all S2k's.
Old Jan 27, 2013 | 03:41 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Current sensor is on all 00-05 s2ks.
It is behind the drivers side s2000 emblem, behind the fender. You will need to pull the fender liner to access.
Old Jan 27, 2013 | 11:02 AM
_brandon's Avatar
But isnt that where the air pump is too??
Old Jan 27, 2013 | 11:48 AM
slowd16's Avatar
Air pump is in the front bumper on the drivers side just under the headlight.
Old May 7, 2013 | 05:04 PM
Lttakas's Avatar
Why is the current sensor tied into ESP module? Lets say i take out the current sensor will I loose power steering?
Old May 8, 2013 | 11:42 AM
jsenclosure's Avatar
no you will not, the current sensor is only for the air pump
s2nick
Dec 28, 2017 11:49 AM
bgoetz
Nov 21, 2016 06:37 AM
will010100
Nov 3, 2016 05:18 AM
Ddub-S2K
Feb 25, 2012 05:52 PM
s2k dre
Aug 7, 2009 01:55 PM
