Air Pump Delete, Removal of actual sensor
I am deleting the airpump, minus that stupid hard line which was a giant PITA to wiggle out everything was straight forward. Now I am to the actual sensor and there is a hardline going into it. My question is do I cut these wires or is there some other way to remove it?
If by giant sensor you mean the current sensor in the fender, it has a wiring harness that unclips; the picture in the instructions show everything that can be removed and all the pigtails, full length of lines, etc. The sensor can be removed by unclipping the fender liner, the fender itself does not need to be removed, removing the front tire will make it easier. There is a bolt or two in there holing the sensor to the chassis iirc. If the end of the sensor pigtail is concerning, you could electrical tape the end closed.
Jj
Ddub-S2K
Feb 25, 2012 05:52 PM
