Alignment Probem: Need Help
Old Sep 7, 2006 | 08:42 AM
hippishake's Avatar
Default Alignment Probem: Need Help
Please Help!!!
Original owner of 05 and has 32K miles.
Started noticing steering wheel misaligned to the left and drifting
to the right. Front tires are wearing much faster on the inside of both
front tires. Took car to local alignment shop and told them the problem.
After alignment, the drifting and steering alignment have not been resolved.
I've checked their aligment results and they are within spec.
Anyone has any suggestions???
Old Sep 7, 2006 | 08:51 AM
Ek9's Avatar
Ek9
Banned
How much front camber is the paper showing? How much toe?
Old Sep 7, 2006 | 10:18 AM
xviper's Avatar
Has the car been in a severe collision?
This is just a steering positioning problem and not an alignment problem as such.
drifting to the right.
Does this happen on a perfectly flat road surface or only on a "high crown" road? It may be normal.
front tires.
This is also normal. In fact, your rear tires should be doing the same thing. It's our normal camber and toe that does it.
Old Sep 7, 2006 | 12:03 PM
SpitfireS's Avatar
All the above & check your tire pressures on all four when cold.
Old Sep 21, 2006 | 12:44 PM
hippishake's Avatar
Don't mind the tire wear as much as the misaligned steering wheel is very irritating.
Tire pressure are even @ around 32 psi.
No accident.
Front camber intial and after alignment:
L: -0deg24'
R: -0deg24'
Front toe initial:
L: 0.00"
R: 0.05"
Total: 0.05"
Front toe after alignment:
L: 0.10"
R: 0.10"
Total: 0.25"
alarose64
Sep 9, 2016 06:02 AM
Aristoi
Jul 27, 2009 10:44 AM
sillyboybmxer
May 5, 2009 09:40 AM
Runaround
Mar 7, 2005 10:24 AM
MDS2K
Dec 29, 2001 05:47 AM
