Alignment Suggestions for slightly lowered
Hello everyone. I finally picked up my car today after being in the shop for over a month (Hit a curb).
I will be installing koni yellows this weekend on stock springs. From what I have read, using the lower perch gives me about a .5 inch drop.
Currently I am using oem ap2 v1 rims with 215/45 fronts and 255/40 for the rears.
Since I will be taking the car to get aligned sometime next week, I was wondering what specs you all suggest. This is my daily driver, although I only work a mile from my house. I would like decent tread life.
Would the CR or UK alignment be better for me? Which one?
You are only putting it on the lower perch of a koni. It's not low enough to warrant changing anything. -1.0 degrees is still -1.0 as far as measurements changing in relation to suspension height. Just use the stock specs if you liked the stock specs before.
