Another Engine Stall Thread
Old Jul 17, 2019 | 03:46 AM
  #81
HawkeyeGeoff's Avatar
Originally Posted by jyeung528
do you have pics of the damage? i have never heard or seen exhaust manifolds or exhausts cracking...how common is this, if not related to install error?
I don't have any pics of the crack because I could barely see it anyway. Just handed it to the welder.
No idea how common this is....its an OEM Mani so I doubt install error.
Old Jul 17, 2019 | 06:45 AM
  #82
fatjoe10's Avatar
Out of curiosity, was this exhaust manifold bracket missing prior to the crack appearing?
Old Jul 17, 2019 | 09:48 AM
  #83
Nope, it was there. I took that off and reinstalled it.
Old Jul 17, 2019 | 11:07 AM
  #84
Chibo's Avatar
If you want an easy one, go look at where the stock exhaust does the Y under the trunk. I guarantee there are cracks all over.
Old Jul 17, 2019 | 11:36 AM
  #85
joelzeller's Avatar
Hey fatjoe, Mine is missing on my OEM header... Will this cause anything? I have a ticking noise I am trying to diagnose... Maybe it is an exhaust leak?
Old Jul 17, 2019 | 11:43 AM
  #86
If you want to do the same test I did.....
https://blog.fcpeuro.com/how-to-diag...ith-a-shop-vac
Or use an air compressor like me.
Old Jul 17, 2019 | 02:41 PM
  #87
fatjoe10's Avatar
With that bracket missing, there is the potential for excessive twisting of the manifold, which can cause cracks. Sometimes, an exhaust leak can sound like a ticking noise. I have tested this by removing 1 nut of an exhaust manifold with the engine running (non-s2000).. go figure lol.
Old Jul 31, 2019 | 04:23 AM
  #88
joelzeller's Avatar
Fatjoe,
I checked for leaks at the manifold using the shopvac method as well as engine running (still cool), and found nothing visible to me. Is there a specific spot that will crack because of a missing bracket? I added the bracket to my car anways.. It also does not happen immediately on start-up, only after about 30 seconds of idling does it start to tick. Do these symptoms point to an exhaust leak?
Thanks! - JZ
Old Oct 16, 2019 | 11:40 AM
  #89
licelsior's Avatar
Just to update this thread since I had this problem.
I borrowed a friends throttle body since I was consistently getting low TPS circuit voltage codes with the omnipower TPS adjusted to OEM spec. Once I did that, it fixed my engine stalling issue as well as the low TPS circuit voltage.
Comparing the throttle bodies, mine had 130k and it appears as if the plate was sticking. Other throttle body had about 40k miles and had no hesitation when opening and closing the throttle.
After 3 years of chasing this issue, finally solved it after spending $$$ on new parts.
FF2Skip
Apr 3, 2008 05:29 PM
124Spider
Nov 8, 2007 01:23 AM
bri822
Dec 19, 2006 01:52 PM
cjb80
Sep 21, 2003 11:22 PM
The Unabageler
Nov 18, 2002 01:42 PM
