Another hesitation S2000
Old Jun 11, 2016 | 08:20 PM
  #31
windhund116's Avatar
How many miles on the clutch disc?
Old Jun 12, 2016 | 04:35 AM
  #32
kikkomon's Avatar
Everything Looks original and untouched so I'd say 45k. I don't notice any clutch slip.
Old Jun 12, 2016 | 05:27 AM
  #33
kikkomon's Avatar
Anyone have any experience with fuel vapor lock? When I open the gas cap I hear air rushing. Not sure if it's going sucking or blowing.
Old Jun 12, 2016 | 05:59 AM
  #34
G3O_-X-_'s Avatar
You might have the same problem as my car have!
We have checked everything and i mean EVERYTHING...you are not going to find the proplem!!!
The only "solution" is to buy an aftermarket ECU...! When they first told me that i laughed...i said no way...i will find the problem...well i haven't!!!
And those who told me for the aftermarket ECU...were people who have experienced the same symptoms and eventually gave up.
I have talked to many people here who have the same problem, and from my understanding it's a factory malfunction...but go figure after ~17 years that the car is in the market!
Old Jun 12, 2016 | 08:15 AM
  #35
kikkomon's Avatar
I've had other ap1s. I don't believe that this is a factory malfunction but i'm inclined to entertain the idea. To solve that problem would be standalone or kpro. I don't want to go that route yet considering costs, although this car WILL eventually be boosted.
Old Jun 12, 2016 | 08:16 AM
  #36
kikkomon's Avatar
I noticed the fuel pump was VERY quiet compared to other s2ks I've had. I could barely hear the buzz when I turned on this ignition. My next step i'm guessing would be to remove the pulse damper in the fuel rail and attach a gauge. I also pulled each coil while the car was on. The #4 coil didn't change the engine rpm like the other 3 did. I yanked it off 4 times and the engine didn't change much. I'll go ahead and replace this coil and go from there.
Old Jun 12, 2016 | 08:55 AM
  #37
G3O_-X-_'s Avatar
I'm not saying it's a problem on all s2ks!
As fas as the fuel pump, i have measure both pressure and l/h!
Old Jun 12, 2016 | 09:44 AM
  #38
kikkomon's Avatar
Originally Posted by kikkomon' timestamp='1465748108' post='23991388
[quote name='G3O_-X-_' timestamp='1465739973' post='23991321']
[/quote]
Measure L/h by letting it run into a bucket? What would be the cleanest route?
Old Jun 12, 2016 | 10:15 AM
  #39
G3O_-X-_'s Avatar
I took it to a workshop to do it for me, along with the injectors (clean, measure). I think they put it in a machine or something...
Old Jun 12, 2016 | 11:57 AM
  #40
kikkomon's Avatar
Anyone have a link for that banjo bolt to install a fuel pressure gauge?
S2Kart
Oct 21, 2016 12:01 PM
Hondatuner82
Apr 22, 2014 05:56 AM
h4mmer
Nov 30, 2013 12:08 PM
Devinb
Dec 23, 2011 07:21 PM
j8mie
Oct 3, 2007 06:59 AM
