any diff sugestions?
Old Mar 20, 2006 | 08:11 PM
Quivers's Avatar
Banned
Default any diff sugestions?
I blew my diff, Its still very drivable but i need to order a new one soon, anyone have a suggestion?
Old Mar 20, 2006 | 08:23 PM
koji187's Avatar
you will need more then a lsd...the whole pumpkin...(diff housing)
Old Mar 20, 2006 | 08:33 PM
Quivers's Avatar
Banned
you suck, stop costing me more money.
Old Mar 20, 2006 | 08:35 PM
Slows2k's Avatar
Product inquiry, moving to S2000 Talk
Old Mar 20, 2006 | 09:42 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
OMG,do I feel for you.!!!
Old Mar 21, 2006 | 06:17 AM
Wisconsin S2k's Avatar
eh?
If you blew your diff, the car would not be driveable...... And what do you mean by "blew your diff". What broke? and how do you know? again, if you broke a pinion, ring gear, or the LSD, you would not be able to drive the car.
Old Mar 21, 2006 | 06:23 AM
quickysrt's Avatar
go to jdm side of the forum their is a whole subject going on about lsd's right now.
Old Mar 21, 2006 | 06:24 AM
Quivers's Avatar
Banned
I felt no difference in drivability, I have a clinking noise that is speed dependant, I dont hear it when thier is a load on the drivetrain (like engine braking or accelerating. when I lift my car and spin the tire the opposite tire spins the same directon for a few turns, stops turning then continues in the same direction. I havent had time to pull everything apart yet but im going to drop everything on saturday.
Old Mar 21, 2006 | 06:35 AM
If you have a clinking noise, yet you can drive the car, you did NOT destroy your diff, ring gear, pinion, lsd, etc. You could have a bad wheel bearing, or you could have a bad pinion bearing. If you had snapped a tooth off of anytihng in your diff, which would cause a clinking, you wouldn't even be able to drive the car for very long, as the shearing forces, and the tooth roaming around inside the diff would take out more teeth and possibly even the LSD.
Your diff is not bad.
Old Mar 21, 2006 | 06:42 AM
Quivers's Avatar
Banned
sounds good to me. Actually my wheel bearing has been blown for nearly a year, I just forgot about it till now cause it was only a busted spline. Ive said it before aand I will say it again Im a dumbass. I seriously almost ripped out my rear end last night.
