any diff sugestions?
Old Mar 21, 2006 | 07:38 AM
Wisconsin S2k's Avatar
also, re: pinion bearing.... when a pinion bearing goes, it usually makes a whining, not a clicking. but, if it does go bad, often times you'll see oil leaking out where the propeller shaft connects to the diff.
Old Mar 21, 2006 | 08:11 AM
Quivers's Avatar
Banned
I have no leaks or whine, just clicking when coasting
Old Mar 21, 2006 | 08:22 AM
Silver9k's Avatar
I think I have the same clicking...I also believe it is my diff. I've had it for a year though now and it hasn't created any problems.
My Problem: Get a clicking noise about once a second at 7mph (happens between 5mph and 17mph) while turning...the harder the turn the faster the clicking. Only happens when in neutral or if clutch is depressed. Will not happen when engaged in gear. I've taken apart my CV Joints, regreased them, regreased the splines and examined for any leaks and everything is ok...the LSD still does what it is supposed to. This first started, or at least was first noticed after some hard autoxing.
But again, I don't know what it is...had it for a year now and it has been ok. I'm just going to buy a diff with 4.57s and ship my diff back and the the core charge back. Hopefully that fixes the problem. But yes the diff works.
Old Apr 26, 2006 | 03:34 PM
Double'SS''s Avatar
[QUOTE=Silver9k,Mar 21 2006, 01:22 PM]I think I have the same clicking...I also believe it is my diff.
trymev8
Aug 25, 2009 07:56 PM
timlee2002
Jul 30, 2009 04:19 PM
moey1188
May 11, 2008 06:50 PM
