Any harm with 6qts of oil?
uhm, the guys running 6, these are the people who go and dyno 180-190 rwhp. windage sluffs off tons of HP. your car will get shitty mileage, and seriously, barely be able to beat a well driven tiburon. trust me, ive done more oil sling tests than you can figure. between the half qt low, and a nickel width over full marks,, you losing about 25 hp. no 6qts is not OK. unless you drive like an old lady and dont care about power. then its fine. later dave
Originally Posted by Silver9k,Oct 31 2005, 11:18 AM
but what if it takes 6qts. to reach the full mark?
The S2000 2.0 liter needs 5.5 quarts of oil. The distance from L to H on the dipstick is 1 quart. Thus if you are down 3 X
the bottom line is this:
if it takes 6 quarts to reach the full mark, then use 6 quarts.
in other words, use whatever it takes to get to full. DO NOT OVERFILL. you should NOT see the oil reading above the full mark. and as stated, check BOTH sides of the dipstick and use the lowest reading.
[QUOTE=dlq04,Oct 31 2005, 09:48 AM] Be aware that the oil dipstick goes through the cylinder head, so engine oil draining back into the oil pan can wet the dipstick and give deceptive readings. So look at both sides of the dipstick, and then use the lowest reading.
good points. whatever it reads at operating temp, thats whats important. never check it cold. run it, at least 20 miles. then park it, let stand for 15 minutes. do at least 5 dips. and see what you come up with.
at 5 even mine is always at the full mark. and i have a huge shop, and let it drain while i do other stuff. and always run a factory filter. so i dont know why, but mines on 5 qts. soon ill have cooler and extra lines, ill have 6 qts then...
later dave
later dave
later dave
later dave
Although this hasn't come up, I will toss it into the discussion as well. Don
