Any warning of cracked retainers?
Old Feb 9, 2019 | 07:15 AM
rpg51's Avatar
That is a great pic Slowcrash. But, I think it is the "keepers" that would be sunk below that line that is drawn on the "retainer" in your pic. Correct? Normally with an uncracked retainer the keepers are visible with the top of the keeper approximately flush with the line on your pic. From the top the retainers themselves generally look fine, even if they are cracked underneath. But, the unseen cracks in the retainer allows the keepers to sink down lower than normal. Right?
To the tread starter - like the others have said - this is the perfect time to pull your valve cover, inspect your retainers, and check/adjust your valves if needed. Order a gasket set in case you need it for reassembly. Given the time since it was last pulled off, (if ever), I would just replace the valve cover gasket and maybe even the spark plug tube seals. Have you ever adjusted valves before?
I predict your retainers are fine. But, there is only one way to find out for sure. You have to have a look.
Old Feb 10, 2019 | 10:35 AM
tehlonz's Avatar
Take it apart.
There is no way for any of us to put your mind at ease.
Also, you need a valve adjustment.
yamaha6611
Jun 11, 2017 06:08 PM
s2000amuse
Nov 12, 2006 11:14 AM
321contact
Sep 15, 2005 06:05 PM
321contact
Sep 11, 2005 09:09 AM
Stale_Hotdog
Mar 31, 2003 07:07 AM
