Anyone done a compression test lately?
Originally posted by gernby
"3"
"3"
I know this is an old thread, but it seemed like as good of a place as any for my follow-up question:
If you do a compression test and the numbers look good, is there any value in doing a leak-down test, also? Is there a possibility that it will uncover something that wasn't seen during the compression test? If so, what kinds of things might it reveal?
One thing that I've heard is that a compression test can be skewed higher by carbon buildup causing the instantaneous cylinder pressure to be higher (due to the increased CR) even though it may not be holding that pressure very well.
Gernby, I'm not expert, but if a compression test shows everything is within spec, I don't think a leak down test is needed. Leak downs help you pinpoint exactly where the problem is because you can follow (hear) the air coming out of the intake/exhaust side (in the case of valves), or you could have air blowing out your crankcase (rings), and maybe in very rare cases, between cylinders (crack/headgasket).
