Anyone Install their own control arm?
You'll need a "ball joint separator" for the lower ball joint, the one with the castle nut. The two inner bolts (one is a bolt within a larger adjustable collar) set the caster/camber anngles, you'll surely have to get re-aligned. Other bolt is the main shock bolt, and the sway bar link needs to be disconnected also.
