removing front lower control arms
Old Aug 21, 2013 | 04:50 AM
Clark's Avatar
Default removing front lower control arms
I'm pulling all the suspensions arms to do bushings. It's all going quite swell, except for one item; the cam collar on the front arms. This is the vertical bolt & collar combo toward the rear. The collar is the part with the caster adjuster in it.
Is there any 'trick' to getting this out? The bolt came out no problem, but the collar bit seems to have no vertical movement. I can turn it as one would to adjust caster, but no vertical movement. It is too snug up against the subframe to get a pry bar or screw driver in to pry it.
Somebody out here has to have the secret. Give it to me and I'll give you some magic beans.
Old Aug 21, 2013 | 05:27 AM
iamxpl's Avatar
known issue with the S2000's these sometimes get seized. and more than likely it has seized onto the compliance bushing.get a sawzall and cut.
https://www.s2ki.com/s2000/topic/935...ance-bushings/
award78
Apr 26, 2017 10:54 AM
pputkowski
Nov 23, 2008 12:41 PM
SoCalIsMyLife
Aug 27, 2007 07:51 PM
YeLLoWs2knVA
Feb 13, 2004 09:29 PM
