Anyone reuse washers on tranny/diff. fluid changes
Old Feb 1, 2005 | 06:02 AM
baldy74's Avatar
Default Anyone reuse washers on tranny/diff. fluid changes
Has anyone tried reusing the washers when doing a tranny or diff fluid change? I was curious if it was ok to reuse them.
Old Feb 1, 2005 | 06:10 AM
QIKSILVR's Avatar
I did, so far no problems in about 5000 miles.
Old Feb 1, 2005 | 06:18 AM
Hondassport's Avatar
I do, have done so since 1992 on various Honda cars
Old Feb 1, 2005 | 07:15 AM
cyber_x's Avatar
I've also reused both and haven't had any problems.
Old Feb 1, 2005 | 07:22 AM
baldy74's Avatar
Do you have to install it the same way it was when you took it off, or with either side work?
Old Feb 1, 2005 | 07:23 AM
Gernby's Avatar
Former Sponsor
I usually don't reuse them, but if I do, I flip them over.
Old Feb 1, 2005 | 07:34 AM
Stratocaster's Avatar
Agreed. So do I. I found that my local dealers don't stock these. So I figure they do it too.
Note: I have ordered a few of them from Hardtopguy the last time I order filters and other misc parts. So Now I have them.
Old Feb 1, 2005 | 07:44 AM
The washers are directional, if you look at one closely you will see a flat and a convex side, the flat side goes against the case whether it is the tranny,diff or oil pan. I make a effort to keep them on the plug when off and they will not get on wrong.
Cya Pete
Old Feb 1, 2005 | 07:56 AM
xviper's Avatar
I've re-used them many times. I don't flip them since I noticed that the washers develop an "impression" or indentation mark and I don't want to risk flipping them in case these impressions don't line up.
The only one that really needs close attention is the diff fill bolt washer. It appears to be made of a yellow metal and it is much solfter. In time, this washer can squash very thin.
Old Feb 1, 2005 | 08:08 AM
Gernby's Avatar
Former Sponsor
It is because of the impressions that I do flip them. The washers need to squish to make a seal, and if they aren't flipped, the old impression may be slightly out of place and not seal well.
