Ap1 > Ap2 Tranny conversion
Old Jan 12, 2009 | 04:16 PM
mrscbw's Avatar
Default Ap1 > Ap2 Tranny conversion
I was wondering if you can bypass the output flange conversion by getting the AP2 driveshaft and differential instead of using the AP1 driveshaft. Thanks.
Old Jan 12, 2009 | 07:07 PM
Slows2k's Avatar
AP2's use larger bolts in both diff and trans flanges that AP1's.
If you want a AP2 trans in a AP1 your options are:
1. Swap trans flange, use AP1 shaft, diff and bolts.
2. Swap diff flange, use AP2 shaft, and bolts.
3. Swap AP2 diff, use AP2 shaft and bolts.
Option 2 can screw up the pinion preload if you don't do it right and trash the differential.
Old Jan 12, 2009 | 07:13 PM
HornyPhil's Avatar
Upgrade the entire system would be my suggestion. Go all AP2 so it all matches.
Old Jan 12, 2009 | 08:50 PM
mrscbw's Avatar
So the answer is yes, you can bypass the flange conversion by using an AP2 driveshaft, diff, and bolts. Thanks.
Old Jan 13, 2009 | 04:40 AM
mrscbw's Avatar
Well I guess this leads to another question...does the AP1 axles work with the AP2 diff?
Old Jan 13, 2009 | 07:52 AM
S20004ME_PDX's Avatar
Yes it does.
I have the exact setup you are talking about. I'm running AP2, tranny, drive shaft and diff with my AP1 axles.
Old Jan 15, 2009 | 11:02 AM
mrscbw's Avatar
[quote name='S20004ME_PDX' date='Jan 13 2009, 08:52 AM'] Yes it does.
s2kq8
May 20, 2016 01:43 PM
RedSunS2K
Mar 20, 2014 06:54 PM
BB02s2k
May 22, 2013 02:22 PM
Nhan
Apr 3, 2007 08:51 AM
eraxpres
Apr 19, 2006 03:40 PM
