AP1 ecu's on AP2 F22 engine?
Old Apr 18, 2006 | 09:17 AM
s2kBryan916's Avatar
Originally Posted by Elistan,Apr 18 2006, 05:49 AM
Did you actually calculate out the amount of acceleration you would have past 8000rpm and compare that to the amount of acceleration you would have after shifting at that point? I suspect if you run the numbers, you'll discover the acceleration is much greater by continuing to 9000.
It'd be a good class exercise to actually calculate those numbers.
I would have wanted to .... but then again we couldnt get an ap1 ecu for free from honda ..... and we spent most our team money on parts
As far as the shifting at 8 because of not enough power gain at 9 is what I heard down the grape vine.
Old Apr 18, 2006 | 09:26 AM
[AP2-2NV]'s Avatar
someone put an ap1 ecu on an ap2 and lost some power. not much, and nothing an e manage or v-afc couldn't fix.
an ap1 ecu with an emanage sounds like a good option for an ap2 anyway. much cheaper than standalone or an aftermarket ecu. but you would need either an ap1 cluster, or a shift light to determine where you're shifting, and i wouldn't take it past 8500. imo the ap2 only needs a little more revrange.
Old Apr 18, 2006 | 10:57 AM
timg's Avatar
I'll say this, a tuned EMS map for a F20C is too lean and has too much timing for a F22C. The stock EMS may run rich enough and conservative enough that it doesn't matter though. I had to add 10% more fuel to a F20C AEM EMS map to get it to run my F22 safely.
Tim
Old Apr 18, 2006 | 11:46 AM
Wildncrazy's Avatar
It has been said that using the earlier, richer ecus (00-01) is the trick set up.
IIRC Billman has had several that DO run to 9000 regularly and they have all stayed together.
It seems that most who say it won't do it have never tried it.
The threads were also full of people who said you can't turbo the engine until it become commonplace.
The naysayers quickly jump on the bandwagon once they are proven wrong and conveniently forget they ever said otherwise.
I know of 2 who have done it for over a year, the cars are not streeted, they are track only. No problems to date.
Old Apr 18, 2006 | 11:54 AM
Wisconsin S2k's Avatar
I have seen the exact opposite posted. Please find the posts and give us links.
proof? you want proof? how about the people like Ultimate Lurker and others that have posted the exact reasons why you shouldn't redline an F22 to 9000rpm on a regular basis. The only proof so far has been the exact opposite of what you're claiming. The rod angle and stresses are too great. Again, revving an F22 to 9000rpm is like revving an F20 to 10,500+ rpm.
If you know more than those people, please feel free to try and convince us of that.
threads please?
Old Apr 18, 2006 | 12:08 PM
here. education is your friend.
https://www.s2ki.com/forums/index.php?showt...dpost&p=5789529
2.2 AP2 engine failure with an AP1 ecu. this was at 8800rpm.
picture of the pistons:
http://www.itepsa.com/samples/SIET199907_CH1_MAIN.PDF
On page 6, Honda says that they reached the critical level of piston speed (24,x m/s) and piston acceleration (45xx m/s
Old Apr 18, 2006 | 05:25 PM
AusS2000's Avatar
2.2 supposedly salvage from 04 with only 7 mi.
swapped into racecar with '00 ecu /VAFC , only survived about 1/2 dozen test or race days at Cal Spdwy and Buttonwillow, no real break in
had poor tune 1st day(lean). Repeatedly revved past 8000, peak recorded ~8800,
driven full out for its short life.
Not really arguing with your point but you have to confess this isn't just an "AP2 with AP1 ecu". It's an unknown block in a race car not run in or tuned and thrashed to death.
Hardly conclusive.
Old Apr 18, 2006 | 05:53 PM
Wildncrazy's Avatar
Every post I've ever seen of blown 2.2s running to 9k have all had the "poor tune, running lean" added to it. Is there a connection, methinks so.
Old Apr 19, 2006 | 06:59 AM
Hardly conclusive.
it's not an unkown block in the sense that it was some random block they bought. they said it was from an AP2, and it looked in great condition, but they were unsure whether it really only had 7 miles on it or not. either way, if there had been something wrong with the block BEFORE they put it in, these guys of all people would have seen it.
also, it only had a poor tune for the FIRST track day. the other 5 or 6 before the engine blew it was tuned just fine and running as it should have been.
as for the "race car" aspect, our friend here said he has two AP2 "race only" cars that have been racing fine for 2 years. yet these guys who are probably some of the best at what they do couldn't get one to last for 7 races. my point is, it is not a question of IF it's WHEN. period.
Old Apr 19, 2006 | 07:06 AM
[QUOTE=Wildncrazy,Apr 18 2006, 07:53 PM] Every post I've ever seen of blown 2.2s running to 9k have all had the "poor tune, running lean" added to it.
jaundice
Feb 20, 2014 07:36 AM
woodburn
Sep 6, 2011 09:42 PM
JajjoTattoos
Jul 6, 2011 04:15 AM
FormerH22a4
Aug 13, 2009 11:07 AM
