AP1 Idle Issue
I have the same issue right now that has slowly been getting worse. The issue is more noticeable after having been driven for a bit, so I figured it was heat soak. I will have to come see you soon to get this fixed Jason!
So you have already replaced the TPS, and then you re-calibrated it? I understand how to test the TPS with a multimeter from reading the service manual, but I haven't seen a procedure on how to adjust it, only to test that its outputting the correct voltage and increasing smoothly with no flat/dead spots.
To re-calibrate the throttle position sensor you can slightly loosen the bolts holding it to the throttle body and rotate the throttle position sensor clockwise or counter clockwise, until you find that it reads the correct voltage.
This image shows it all pretty well.
Heh, well unless your TPS has been tampered with it can probably be a number of things. Start with the IACV.
Found a video showing the process of adjusting the TPS: https://www.youtube.com/watch?v=J7Ks...ature=youtu.be
i had the same problem before and i have posted with data.
it was due to huge vacuum leak from catchcan( pcv to Intake M.) and a minor leak from tps
fixed that up and adjust to 7.1% running good.
tps should be set to about 6% , 5.9~6.3%
