AP1 tranny vs ap2 tranny
Old Feb 22, 2012 | 06:11 AM
p0staboy's Avatar
Default AP1 tranny vs ap2 tranny
So I'm in the market for a transmission for my boosted AP1 and I'm not sure to shop for a ap1 or ap2. Ap1 seems to be cheaper so I'm asking is their really a difference between the ap1 and ap2? It will be going on a boosted car. The gearing is the same correct?
Old Feb 22, 2012 | 10:44 AM
stupkid's Avatar
It's not the same gearing from what I've read.
The secondary reduction gear is shorter, along with the first 4 gears which makes the ap2 transmission feel like an ap1 transmission with a 4.3 final drive gear.
The last 2 gears on the ap2 transmission is taller however.
Also carbon syncros on the ap2.
Note: this is all from what I have researched in the past 2 months. I've been thinking about a swap from ap1 to ap2 too.
Old Feb 22, 2012 | 10:55 AM
starchland's Avatar
For an N/A S, the ap2 tranny seems like a great mod, however you probably dont want shorter gears if your boosted. The ap2 tranny definately shifts alot easier and softer.
Old Feb 22, 2012 | 11:01 AM
Drkphnx's Avatar
This is true dependent on how much power you will be making. shorter gears are not necessarily bad on a boosted S2K, I believe Sideways posted which gears are optimal at what horsepower rating.
Old Feb 22, 2012 | 11:24 AM
GSteg's Avatar
AP2 has shorter 1st through 5th gear while 6th gear is longer
Old Feb 22, 2012 | 03:16 PM
p0staboy's Avatar
So is the AP2 tranny noticable stronger?
Old Feb 22, 2012 | 04:02 PM
stupkid's Avatar
As in tougher/durability?
Old Feb 22, 2012 | 07:37 PM
steven975's Avatar
it's basically the same casing holding the shafts, and pretty much the same gears, so I'd say strength is probably the same.
Gears 1-4 are actually the same exact ratio as the AP1, and gear 5 and 6 are a little taller...
BUT the different primary reduction gear makes 1-5 effectively shorter (5 is VERY close) and 6th is taller.
Old Feb 22, 2012 | 07:43 PM
hypforlife32's Avatar
Correct me if im wrong but wouldn't a carbon syncro be able to take more of a beating then a brass syncro like a ap1 trans?
Old Feb 23, 2012 | 05:34 PM
JDMpearlwhyteZ's Avatar
Well considering that people aren't grenading their transmissions because of the syncros, I doubt it matters..
