Ap1 whistle
Old May 20, 2012 | 06:38 PM
Hlove44's Avatar
Default Ap1 whistle
I have an 03 S2000. it has about 84k miles on it and I've hit a few problems with it.
The most annoying one is a strange very high pitched squeaking when I'm on the gas. well if i press the gas slightly it doesn't do it and when i floor it it doesn't do it either but when I'm anywhere in between it has a high pitched noise that comes from the engine bay that's absolutely horrible! i was told it might be a lose hose so i checked all my hoses they are all fine then i figured might as well try changing the PCV valve and didn't do anything. I'm not sure if it goes hand in had with another problem but my car also idle's around 800rpm 850 when it's warm and when I put the top up or down or even just turn my lights on the RPM'S drop to around 500 600 and feels like its about to idle. like i said i have no idea if they are together but just saying.
also what is the right fluid to put in the differential? I've been told so many different ones and also have been told honda changed it a few times so that would be great as well!
thank you for your time and thank you for any help you can give me!
Old May 20, 2012 | 06:59 PM
zeroptzero's Avatar
Any changes to the intake system ?, an aftermarket intake or even a K&N drop-in filter can do this.
Old May 20, 2012 | 10:12 PM
The N/A Way's Avatar
I think I have the same thing its strange its at an exact point some where between 1/3 and 1/2 throttle, doesnt matter about speed or RPM just throttle position.
mine isnt to unbearable but really strange and dont know where to start looking, just though it has something to do with the air speed whistling through somewhere on or in the intake.
Old May 20, 2012 | 11:10 PM
mattstryfe's Avatar
^ This = me also. Multiple intakes. I tell everyone its my mini turbo whistling...
OP, to put your mind at ease a little. Mine's been doing this since I purchased it @ 18k miles or so. I am now at 97 and change. I don't want to tell you to not worry about it but it has caused me no problems whatsoever.
Your other issues are seperate from the whistling. Your idling problem sounds like a dirty IAC Valve.
Guide to cleaning it here.
Try this first. It's cheap, you can do it yourself, and you'll learn a bit about your intake workings.
Moving on... Differential fluid is preferential just like any other fluid you put in a vehicle. Just make sure is 75w90. Mobil makes some good stuff. This is what I used.
Here's the DIY for changing the dif fluid.
Old May 21, 2012 | 09:26 PM
Hlove44's Avatar
I have an injen cold air intake.
Old May 21, 2012 | 09:33 PM
Hlove44's Avatar
yes that's exactly how it is. I try and say the same but i drive 45 minutes to work and same back haha so that noise gets very old after 25 minutes to the point where i just blast my music haha
also i just hit a new problem. my passenger window just joined my driver side window by being broken... the motor is fine but the window on both sides just fell about 2 months apart and now im assuming is the bracket or whatever the correct term for it is. i was just wondering if it was common?
Old May 22, 2012 | 12:48 PM
B serious's Avatar
That's totally normal. My AP1 does this with a stock intake box and a snorkel. I can hear it over my T1R exhaust. It's caused by air rushing past the throttle body and making a whistling noise...similar to blowing over the top of a bottle.
To get rid of it, you can turn the idle screw counter clockwise a bit on the throttle body. Your IAC will adjust itself to make up for this in a while...so it won't affect anything.
Ignoring it is the easiest fix. It's a normal thing. A lot of Hondas do it.
Old May 24, 2012 | 04:31 PM
Hlove44's Avatar
thanks for the information! I will try the idle screw and if it doesn't work I'll deal
Old May 30, 2012 | 07:38 AM
Andybill's Avatar
Completely normal, dc5's, ek9's,dc2's all do it it's the throttle body nothing to worry about!
Old May 30, 2012 | 03:20 PM
Kory with an AP1's Avatar
Sounds like an alternator whine maybe, this would also may be why the rpms drop when you use anything electrical. most autopart stores can test your alternator and battery.
Spartarus
Nov 8, 2016 03:12 AM
HawkS2K
Jun 5, 2016 12:42 PM
Murphg05
Jan 25, 2015 03:24 AM
Egorbopol
Sep 29, 2010 11:02 AM
Kenn
Feb 10, 2010 04:19 PM
