AP1 Won't Start
Old May 15, 2015 | 09:04 AM
Alen1293's Avatar
Default AP1 Won't Start
Last night I went to turn my car on. It started, but sputtered for a good 5-10 seconds before shutting off. It cranks over but won't start. Any help would be appreciated.
Old May 15, 2015 | 09:56 AM
S_DosMil's Avatar
Do you have gas? Maybe fuel pump fuse blew? Start with the basics
Old May 15, 2015 | 01:07 PM
Backmarker's Avatar
Any similarities to my current issue?
https://www.youtube.com/watch?v=g9W0...ature=youtu.be
Old May 15, 2015 | 02:00 PM
Alen1293's Avatar
It won't start at all. I just towed it to a friends shop to get looked at
Old May 15, 2015 | 02:03 PM
Backmarker's Avatar
Ohhohoho... okay, nevermind then.
I too would start with basics and check the fuse for the fuel pump and such.
Old May 15, 2015 | 06:54 PM
Slowcrash_101's Avatar
Basics means cars need 4 things to start. Compression, fuel pressure, spark, and fuel delivery. If the car cranks over, your battery works, which is good. Next step would be to do a leak down test, make sure you have compression, if that checks out, you have to measure fuel pressure, does the fuel pump cut on when you turn the key to the on position?
If your fuel pressure checks out, and your compression checks out, then it's either ignition related, or a sensor is not working properly. The sensors needed to crank the car over are the TPS, crank angle sensor, MAP, and cam angle sensor. A clogged EGR can stop a car from starting but that's not common on these cars. Ignition wise the coils are pretty reliable, but I would still check the plugs, check their condition, that will tell you a lot.
If all else fails your computer may need to be replaced.
Any codes, check engine lights, engine warning lights?
Old May 15, 2015 | 08:33 PM
windhund116's Avatar
Any chance water got into the fuel?
Old May 16, 2015 | 06:21 AM
Chuck S's Avatar
Only a major failure will cause the car to suddenly not start. Sounds like fuel to me.
You should be able to hear the fuel pump when you switch the ignition switch On. It will pressurize and then stop. First thing to check.
-- Chuck
Old May 16, 2015 | 12:20 PM
vasquezgno's Avatar
I had a similar problem where my car would just crank and crank but not turn on. Ended up being the battery. Replaced it and started right up.
Old May 16, 2015 | 02:39 PM
Alen1293's Avatar
The timing jumped by two teeth. The timing chain is starting to stretch so I guess that's next on my list. At least it runs for now
