Ap2 front end conversion
Old Dec 8, 2006 | 09:26 AM
QuagmireS2k's Avatar
Unhappy Ap2 front end conversion
Hi i am in the process of doing the ap2 front end conversion on my02 bumper and headlights. On the headlights i did not order the new ballasts so i am using the old ones from my 02. The problem is now that i had to dremmel out the socket were the ballast go. That was no problem but now i cant get out the shavings out of the housing. ive tried my air compressor to blow it out but no luck. i was thinking of rinsing it out with distilled water but not sure if would mess anything up or leave water spots inside the housing? Any suggestions how to get the shavings out from people who have done the conversion before.
Old Dec 8, 2006 | 10:31 AM
beanolo's Avatar
Depends where the shavings are, worse case you can bake and open up the housings to clean it out.
Follow the diffuser install baking instructions on Ricks2k.com website.
Old Dec 8, 2006 | 10:36 AM
bracky's Avatar
Try taping some plastic tubing to your vacuum cleaner hose.
Old Dec 8, 2006 | 11:10 AM
USMC2006s2k's Avatar
Post
can you see the shavings through the hole? if so why don't you try putting a piece of tape on a wire hanger try and fish it out?
Old Dec 8, 2006 | 02:56 PM
sexycheto88's Avatar
vaccum?
Old Dec 8, 2006 | 04:22 PM
Thanks for the suggestions everyone. The pieces were really small and in the corners so i just went ahead and rinsed them with distilled water that did the trick Ill post pics when i am done.
Keith
Sep 30, 2008 09:27 AM
ej3ffrey
Jul 15, 2008 09:21 AM
NFRAP1
Nov 9, 2007 05:00 AM
gusrock77
Sep 29, 2007 02:35 PM
ExoticCarSite
Nov 2, 2006 05:10 AM
