ap2 headlight bulbs removal?
Old Aug 16, 2012 | 10:07 PM
thuxuryKB1's Avatar
Default ap2 headlight bulbs removal?
hey everyone.
god i feel like crap asking such a noob question, but i have no manual. how does one remove and replace the headlight high beam bulbs/low beam hid's, parking light and turn signal bulbs?
i was scouring the s2ki forums but couldn't find anything. am i blind? please help!
thanks!
Old Aug 16, 2012 | 10:10 PM
Moddiction's Avatar
Former Sponsor
Pull off the wheels and then remove the clips/screws holding in the fender liner and pull it out of the way to get easy access to the back of the headlights. That or remove the front bumper and headlights to swap them out. Unfortunately unless you have baby arms and hands there is no way to do it from inside the engine bay or anything. Pretty annoying.
Old Aug 17, 2012 | 04:22 AM
Saki GT's Avatar
You can get the high beams out by reaching through the cut outs in the engine bay if you have small enough hands, but the rest of the lights really need to be accessed through the fender wells.
Jack the front of the car, remove a wheel, pop the 3 or 4 tabs that hold the fender liner in and to the bumper, and pull and bend it back and out of the way. Don't be shy about bending that back, the more room you give yourself the easier it is.
Also, be careful about the parking lights - there is a gap between the housing and the back and if you drop the bulb between them, you'll never see that light again.
Old Aug 17, 2012 | 07:06 AM
thuxuryKB1's Avatar
hey guys thanks alot i thot i was gonna have to take the whole front end off whew!
Old Aug 17, 2012 | 08:04 AM
robotvoice's Avatar
Pulling the front bumper only takes a few minutes, then you don't have to jack the car up to remove the wheels. If you're replacing all the bulbs in the headlight assembly it would be much easier to remove the entire light and to them all at once too. You want to make sure you can get the new low beam HID bulbs in and seat them WELL in the headlights too or your beam pattern will be jacked up. Make sure you turn your low beams on and test their output before you put your bumper back on!
Old Aug 17, 2012 | 01:18 PM
thuxuryKB1's Avatar
thanks for the tip. Is the s2000 s bumper made for easy removal? The only other car i had that had an easy to remove bumper was my old e36.
Old Aug 17, 2012 | 03:33 PM
hydralover's Avatar
I could reach it fine from inside the engine bay/reaching around the tire. No jacking or removing here.
Maybe I just have those small hands
MasterForce
Mar 20, 2013 10:50 AM
RPG2ach
Apr 29, 2011 03:12 AM
s4play
Feb 23, 2007 01:47 PM
hk_s2k
May 24, 2006 05:10 PM
