headlight problem
Old May 23, 2006 | 04:43 PM
hk_s2k's Avatar
Default headlight problem
my left hid flickers when i turn it on, then it completely shuts off.. what could be causing this? any help would be great thanks.
Old May 23, 2006 | 05:09 PM
xviper's Avatar
Bad bulb or bad ballast or bad ground.
Old May 23, 2006 | 05:28 PM
Slows2k's Avatar
Swap bulbs side to side to see if the problem moves with the bulb.
Old May 23, 2006 | 08:37 PM
VaragS's Avatar
I posted not to long ago of the same exact problem....i looked up the directions for taking off the front bumper and so on to get to the headlight sounded very time consuming...do u guys think it is worth it to do on my own? or should i just take it in somewhere
Old May 23, 2006 | 08:43 PM
Slows2k's Avatar
You can swap the bulbs without removing the bumper. You remove the clips and bolts holding the inner fender liners in and pull them back to access the back of the headlights.
You will need a tamper-proof torx bit to remove the covers over the HID bulbs.
Old May 24, 2006 | 12:01 PM
cbrace0012's Avatar
I had this same problem, with mine moisture got inside the ballast box. The headlight is very easy to remove by taking the wheel well liner out. I removed the wheel well liner and then removed the 4 screws on the bottom of the HID box , removed the bottom panel,and used a blow dryer to dry any moisture out. I put sealant around the panel and put the screws back in and haven't had a problem since (approximately 6 months).
Old May 24, 2006 | 12:03 PM
cbrace0012's Avatar
Also, if you want to remove the bulb, you don't need a tamper proof torx bit. I removed mine with needle-nose pliers. They aren't tight at all.
Old May 24, 2006 | 05:10 PM
Slows2k's Avatar
Since I have a set of tamper proof torx bits, I've never bothered to try anything else.
PaulG1968
Apr 17, 2014 10:54 AM
S2kmonkey
Mar 29, 2012 08:47 PM
r8byb
Feb 16, 2011 02:31 PM
s4play
Feb 23, 2007 01:47 PM
Sean Juan
Sep 21, 2006 07:21 PM
