ap2 retainers
Old Feb 5, 2013 | 01:36 PM
andy84's Avatar
Default ap2 retainers
Ok so i want to install the ap2 retainers on my ap1 but i am not comfortable doing this myself. Is this something ur everyday mechanic can safely do? Or can a honda dealership do it?
Old Feb 5, 2013 | 01:40 PM
s2000ellier's Avatar
do not take it to the dealership they will pull the head.
Old Feb 5, 2013 | 01:50 PM
darcyw's Avatar
If you're comfortable with valve adjustments and brake work, then you can do this. Get the torque specs from the service manual. Buy the right tool below, and use a quality torque wrench.
http://www.ebay.ca/itm/Honda-Acura-V...0#ht_630wt_903
The amount you'll spend on paying a honda tech, you could own the tools for way less. If you're close to new york, PM Billman's shop.
good luck and be brave.
darcy
Old Feb 5, 2013 | 02:08 PM
andy84's Avatar
Ok thank you
Old Feb 5, 2013 | 02:09 PM
mattstryfe's Avatar
http://www.ebay.ca/i...f0#ht_630wt_903
darcy
This is great advice. I second the part about buying a quality torque wrench. Please also ensure that it's the right size. This is the result.
Good luck. Having the right tool for the job makes a world of a difference.
  • The 10mm Valve adjustment tool in this guide is worth the money.
  • The retainer removal tool in this guide is also worth the money.
My Advice:
  • Do not rush
  • Download or buy a HELMs manual
  • purchase proper tools
  • Allocate enough time (preferably during day light hours)
  • Buy one of those magnets on a stick
  • Read multiple guides and look at multiple images from each one before attempting
  • Print out a couple of the images for reference or use your phone/tablet/laptop
  • If you're not sure about something; look it up in the manual, look at the guide, or come on the forums and ask someone. Billman helped me out the day I was doing mine. I am certain that if someone sees you assistance they will quickly help.
  • Invite a friend over that has done this before.
Old Feb 6, 2013 | 02:54 AM
SouthDakotaS2K's Avatar
It is easy. I just did mine the other day. It took about an hour. I did buy the $11 valve adjust tool off Amazon. It worked great. I also would recommend the keeper tool Lis36200. Easiest tool for removing and installing keepers.
Old Feb 6, 2013 | 05:04 PM
andy84's Avatar
Where did u get the keeper tool from
Old Feb 6, 2013 | 06:56 PM
Amazon, Ebay, or a local parts store.
Old Feb 6, 2013 | 10:55 PM
AZ-S2000's Avatar
ScienceOfSpeed said its about a $300.00 job. Parts and labor I think. Not bad. I think valve-adjustment was included
Old Feb 7, 2013 | 09:42 AM
4forall's Avatar
300 sounds right on the money. 150 for parts and 75/hr for labor. 2 hr job. I would take it to them of you dont want to do it yourself.
