AP2 Transmission Rebuilt, notchy gears when cold
#21
#22
Today I experienced something. When I press the clutch pedal, lets say, when I press just passed the friction point but not down to the floor, the gear engages themselves easier. I'm just trying to figure why. I told you I measure the crank endplay but while the transmission was bolted to the engine. I had around 0.010-0.012 ''. It might be more if the crank stops because the input shaft is backed off and leaned against the transmission housing. I'm off this week, I'll just try to unbolt the tranny and measure exactly the endplay. I've got a feeling that when I press the clutch to the floor, I add more tension on the crank and the clutch might slip a little tinny bit against the flywheel causing that irritating feel because its not fully disengaged. What do you think ?
#23
#26
no matter what oil you use, give this one a try:
https://shop.liqui-moly.de/additive/...l-additiv.html
or this one:
https://shop.liqui-moly.de/additive/cera-tec.html
Makes shifting really much better and smother.
To solve problems with shifting when the gearbox is cold, lower the Viscositiy of the gear oil, just try a 75W.
or this one:
#28
or this one:
or this one:
#29
or this one:
or this one:
I added some Liqui oil additive to the engine oil after swap and I must say the engine feels good or better. Or its due to the oil swap to Shell Helix ultra 5w40. Coming from Valvoline 5w40.
Anyway im considering the gearbox additive. Are you recommending from personal experience and use? Or purely from knowing the marketed product?
Also if you have used it. Did you add 1 or 2 tubes of 20grams to the gearbox?
And is there any downside for the transmission? Its an ap1 90k miles.
Thanks!
#30
I recommend it from personal use. When i bouhgt my S2000, the gearbox was extremly notchy, shifting into 3. gear creates a "recoil" like firing a 9 mm Pistol and selecting the gears was extremly diffcult, it feelt like the shifter stick in old cheewing gum.
First Try: Ravenol MTF II 75w-80 with one tube of LM Gear additiv: Much better, but still very notchy.
Second try: Re-grease the Shifter: MUCH better, selecting the Gear was much easier and more precise. A really rewarding and recomended work.
Third try: Ravenol MTF II 75w-80 with a good dose of Liqui Moly Ceratec: Even Better, but still a little bit notchy. Big Problem was, it grinds heavily when i shift in 5. Gear at High RPM / high speeds. Nobody ever want to hear this sound. Clearrly, i have overdoesd it, this makes the oil to slippery for 5. gear to synchronise properly.
Fourth Try: Rowe 75w-80 plus one tube of Liquy moly gear additiv: Perfect in eavery gear. No more notchiness, but still a very fine "Mechnical - Synchros at Work" feeling on the shifter. I will stay with this.
This is my personal expirience. My long-time expirience with all this additives is: They work, but sometines less is more. 1 Tube of the LM gear additive is enough. I have done this within the first 6000 Miles / 10000 Km since i owned the car, it was worth the work and i have wasted very little money with this experiment.
Try it, i am sure you will not regret it. If it dont work for you, i appologize, but you only have wasted two liters of gear oil and you could change back to a different oil in no time. I think it is worth the experiment.
xdavieexx
16
03-17-2007 06:51 PM
