Auto Lock Issue
Old Aug 15, 2014 | 09:49 AM
neurotic's Avatar
Default Auto Lock Issue
This is likely a stupid issue, for which I couldn't find a resolution with a quick search.
When I unlock the car with the key fob, it relocks simultaneously with opening the driver's side door handle. If I use the handle quickly, the door will open, otherwise it locks before I can open the door. I tried waiting various amounts of time after key fob locking, and the issue is not related to timing but door handle use.
Notably, I recently replaced the passenger's side door jamb switch. Although, it seems to work correctly; the dome light now recognizes the passenger door opening.
Tonight I'll pull the interior door panel to see what it's going on. Has anyone seen this issue and found a resolution, or have an idea where to look?
Thanks.
Old Aug 15, 2014 | 10:12 AM
odb812's Avatar
If you're having the same problem I was, you're driver's side interior door handle is broken. Mine most likely broke from me repeatedly clicking the unlock button as I approach the car. To verify you're having the same problem, try to move the manual lock/unlock tab on the inside by the door handle. If there is no resistance on that then you have the same problem. To fix you need to remove the door panel and replace the handle. When you have the new handle installed, open and close the door and lock and unlock it to make sure everything is aligned properly before putting the panel back on.
I thought I had a better picture than this, but the lower rod with the black piece of black plastic hanging down is the locking rod. The piece of black plastic is the lower portion of the interior lock switch, It's where the locking rod attaches to the locking switch. I guess that piece fatigues from the extra tugs of the power lock and eventually brakes.
Old Aug 15, 2014 | 10:36 AM
neurotic's Avatar
Thanks. There was no resistance with the interior lock tab thing.
I've broken the lock tab before, so I guess I should've recalled this.
Old Sep 24, 2014 | 06:47 PM
smoore's Avatar
I am having a similar problem. when I unlock my car with the fob it relocks after about 10 seconds without me doing anything to it ( like opening the door etc.) Any thoughts?
Old Sep 29, 2014 | 02:52 AM
MM3Kwolik's Avatar
That's normal. The keyless entry is programmed to automatically re-lock the doors if it doesn't sense a door being opened within a specified amount of time.
Petron
May 30, 2014 01:49 PM
lunar_s2k
Sep 8, 2013 09:04 AM
s2000 gib
Jan 3, 2011 03:24 AM
russellhq
Mar 6, 2009 07:47 AM
esracer
Aug 2, 2006 05:45 AM
