Axial Flow Shifter Problem
Old Nov 12, 2007 | 04:40 AM
Jenady's Avatar
Default Axial Flow Shifter Problem
I installed an Axial Flow Engineering short shift lever from Rick's.
The first issue I encountered was its reluctance to be pushed down to go into reverse. It did finally give in.
I found that there is a lot of room to the right of fifth gear. It is like there is no gate to limit travel. Then, yesterday I actually went past sixth as though I was trying to shift into reverse. This makes a very bad noise.
Now I realize the the shifter is stuck down. It still goes through all the gears but it also will go into reverse without pushing down.
Does anyone have an idea what is going on here?
Old Nov 12, 2007 | 05:07 AM
S2KPUDDYDAD's Avatar
Yes, you have it in backwards Undo the screws lift up on the shifter and turn it 180* and reinstall
Old Nov 12, 2007 | 07:15 AM
Jenady's Avatar
The shifter has a spline on one side that prevents it from going in backwards. I did just try to turn it to see if it might go in that way but it won't.
sg611
Jul 6, 2019 12:20 PM
samson123
Nov 3, 2017 09:00 AM
K_mann
May 28, 2014 04:47 AM
ayelien
Jun 21, 2004 09:27 PM
