Axle Assembly
I am looking to assemble a Ap1 shell I have sitting around and coming to a snag finishing up the rear end. I would rather avoid paying 5.38/per bolt from Majestic for the bolts connecting the axle to the rear diff and i know they would be readily available at a hardware store. The issue is i cant find a definite size on the bolts/nuts? Any help would be appreciated! I know i could always just see what fits but i would rather not half ass such an important piece.
I would not use a hardware store bolt, or nut for this. You have been warned. If you must know it's a 10mm thread diameter 1.25mm pitch, and would at least use a self locking nut. Again you have to use at least a grade 8 bolt,at the very least. Doubt you'll find it at a hardware store, but if you can, I suppose you can make it work. You'll want to use a self locking nut, or a locknut washer or something to keep the nut from backing out. Locktite if you're a masochist.
The factory bolts are shouldered high strength flange bolts. Without the shoulder, the axles and diff will work directly against the threads destroying the bolt. You will not find a shouldered bolt like this in any store, anywhere. Anything you buy aftermarket will be full thread, no shoulder.
I wouldn't cut corners here, the bolts are well worth it.
Easiest way to get the right answer on the internet is not to ask a question but to post the wrong answer.
