Axle Assembly
Old Sep 30, 2016 | 10:42 AM
mongomery1234's Avatar
Default Axle Assembly
I am looking to assemble a Ap1 shell I have sitting around and coming to a snag finishing up the rear end. I would rather avoid paying 5.38/per bolt from Majestic for the bolts connecting the axle to the rear diff and i know they would be readily available at a hardware store. The issue is i cant find a definite size on the bolts/nuts? Any help would be appreciated! I know i could always just see what fits but i would rather not half ass such an important piece.
Old Oct 1, 2016 | 07:53 AM
Ttt
Old Oct 1, 2016 | 09:15 AM
Slowcrash_101's Avatar
I would not use a hardware store bolt, or nut for this. You have been warned. If you must know it's a 10mm thread diameter 1.25mm pitch, and would at least use a self locking nut. Again you have to use at least a grade 8 bolt,at the very least. Doubt you'll find it at a hardware store, but if you can, I suppose you can make it work. You'll want to use a self locking nut, or a locknut washer or something to keep the nut from backing out. Locktite if you're a masochist.
Old Oct 1, 2016 | 09:23 AM
I think it's a 17 or 14mm hex head I can't remember. I should just say it's 7/8ths or something and someone will be in to correct me soon enough.
Old Oct 1, 2016 | 10:50 AM
tozerman's Avatar
It's a 14mm head bolt iirc.
Old Oct 1, 2016 | 11:00 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The factory bolts are shouldered high strength flange bolts. Without the shoulder, the axles and diff will work directly against the threads destroying the bolt. You will not find a shouldered bolt like this in any store, anywhere. Anything you buy aftermarket will be full thread, no shoulder.
I wouldn't cut corners here, the bolts are well worth it.
Old Oct 1, 2016 | 11:44 AM
S2Kennyy's Avatar
Agreed with billman, The shoulders are a part of the strength otherwise the 2 flanges can move because of the play.
Old Oct 1, 2016 | 05:39 PM
Like clockwork Easiest way to get the right answer on the internet is not to ask a question but to post the wrong answer.
chubbys2k
Feb 22, 2016 07:11 PM
Carl Bourbon
Dec 29, 2013 05:56 AM
peters2000
Nov 29, 2009 07:19 AM
RGlbk
Jan 5, 2008 02:45 PM
payneinthe
Aug 29, 2006 01:02 PM
