Axles Swap
Old Mar 16, 2009 | 05:36 PM
AusS2000's Avatar
Default Axles Swap
I've got the pitted CV problem and am aware that one of the fixes is to swap the inner CV cups around.
I got a replacement set of axles (CV cup to outer spline). I have already disassembled them and checked for pitting and none is apparent. I regreased, reassembled and took them to the mechanic for fitting.
I asked for them to be installed in reverse. Left on right hand side, Right on left hand side (they are marked L and R) so if there is any wear it will not be on the power surfaces.
After I left two thoughts struck me. Firstly, when I had them apart why didn't I just swap the cups! Secondly, can you install them on opposite sides?
I'm looking for answers to the second question only. The first is self evident.
Old Mar 16, 2009 | 06:06 PM
Slows2k's Avatar
The shafts are different lengths, the joints are the same side to side. No, axle assemblies can't be swapped side to side.
clio
Jul 23, 2016 12:04 AM
cdelena
Sep 20, 2013 05:42 PM
dsthez
Feb 24, 2011 12:32 AM
Calamari
Sep 15, 2010 09:20 AM
