Backfire Through Intake
Old Sep 17, 2023 | 10:15 PM
Aahs's Avatar
Default Backfire Through Intake
I'm having pretty server issues with my s2000. It started with a misfire and hesitation that would go away once warm. It still does this but it now back fires through the intake occasionally when revving. It is very slow to rev but once warm that's the only symptom other than occasionally breaking up.
I've replaced:
Plugs, coils, MAP, valves adjusted, fuel pump, fuel filter, fuel regulator, air filter, passed leak down, passed compression test, clean throttle body, cleaned IACV.
I'm at a loss with it entirely. At this point I'm thinking a bad valve somewhere.
Old Sep 18, 2023 | 02:52 AM
Slowcrash_101's Avatar
Maybe a bad injector.
Old Sep 18, 2023 | 05:46 AM
windhund116's Avatar
I've replaced:
No mods or recent fixes to the cams or ECU?
Maybe, do a leakdown test?
Old Sep 18, 2023 | 03:37 PM
Aahs's Avatar
Only mods are catback exhaust and high flow cat
Old Sep 18, 2023 | 11:49 PM
RolanTHUNDER's Avatar
He did the leakdown but it's good to revisit all variables in case one was missed. This sounds ignition timing related
Old Sep 18, 2023 | 11:50 PM
How did it run before those mods? Since you said it backfires and is slow to respond to throttle I'm guessing ignition timing is off.
Like Slow said it could also be a bad injector sticking when it should be opening and closing smoothly. Maybe more than one. Got access to a spare set of OEM ones to test?
Slowcrash_101
Oct 21, 2014 01:20 PM
project*stealth
Dec 3, 2011 01:38 PM
midnightsunset
Dec 1, 2008 07:26 AM
FitzyS2k
May 14, 2008 07:11 AM
s2000_19
Jun 9, 2005 09:44 AM
