bad clutch or bad trans?!?
Old Apr 10, 2013 | 06:30 AM
andrewv's Avatar
I have an 04 and had the same issue as you. I could put it in 4/5th gear when going slow and give it gas and the clutch would not slip, but as soon as you would shift it in the higher rpms pretty hard it would slip like it was getting wheel spin.
I was planning on my clutch anyway so when I did, the clutch disc was pretty worn and was glazed. After replacing the clutch it does not do that anymore. I still have the cdv on my car and I do not notice it slip one bit after replacing it with a stronger clutch. You might have the same issue I had
Old Apr 10, 2013 | 09:56 AM
ntzz's Avatar
Originally Posted by ikeyballz
Originally Posted by ntzz' timestamp='1365566666' post='22463577
I'm having the same problem with my 02. Just replaced brand new clutch and feels as if the clutch is slipping. Not driving it hard regular daily driving feels like the gear wont catch and i can barely drive. Putting it in first gear it struggles to get to 10mph with it shooting for 4rpm+. This happens throughout all the gears and i really have to baby it to get to higher speeds. I've noticed when weather was colder this issue did not occur until the car warmed up, any ideas?
While this is off topic - did you get the clutch changed at a shop? Its likely you didnt break it in properly or the shop didnt clean the PP/got grease on the clutch plate. Also possible that its an improperly adjusted clutch pedal. I doubt they'd put in a new slave cylinder (new slave has the CDV) into your car for just a clutch change.
Yeap it was done at a reliable shop and i highly doubth the CDV was replaced. Is this expensive to replace??
Relentless_AP1
Aug 13, 2015 11:24 AM
dragoon218
Apr 10, 2013 06:14 PM
amirgho
Aug 23, 2012 08:22 PM
hitten9k
Nov 4, 2009 01:38 PM
lols2000
Jun 23, 2009 04:07 PM
