BAD ECU (COMPUTER) NEED HELP!
Old Aug 23, 2014 | 05:54 AM
eliddm's Avatar
Default BAD ECU (COMPUTER) NEED HELP!
I had the engine light on on my 2006 s2000. The dealer found the ect sensor 2 defective (error p2185 circuit high voltage) after changing the piece and checking the wires (4 hours later!!!!) they tell me my computer is defective and I should replace it (just the piece here in Canada is 900$!) Any advice???
By the way it's an american s2000
Thanks
Old Aug 23, 2014 | 07:36 AM
s2klariat's Avatar
My first ecu used to throw a constant P0411 code. $75 for a used ecu on ebay and $30 to the guy at the dealership to program my keys to the new ecu and it was done.
Old Aug 23, 2014 | 09:39 AM
eliddm's Avatar
I found this on ebay:
http://www.ebay.com/itm/2004-2009-HO...35462c&vxp=mtr
Do you know if it will fit? I know it s AP2 but I fought ecu could be different from year to year.And how can i know it will not be defective the same way?
Thanks!
Old Aug 25, 2014 | 04:28 AM
eliddm's Avatar
Any more advice from someone?
Old Aug 25, 2014 | 05:50 AM
Polaris0352's Avatar
It looks like that ECU should work, and it also sounds like the technician at your dealership has weak diagnostic abilities.
Old Aug 25, 2014 | 10:02 AM
jaundice's Avatar
You have to use an ECU from 2006+. The 2004-2005 AP2 weren't drive by wire and won't work in your car. You might also check into Flashpro and see if that would work for you.
FlushS2000
Jul 7, 2012 02:48 PM
Gios2k^
Jan 29, 2012 08:31 PM
slowpokeS2K
Oct 21, 2011 03:36 PM
OneQuickS2K
Feb 27, 2004 04:23 PM
