Basic maintenance...
Old Jun 1, 2019 | 04:02 AM
pwrful4's Avatar
Default Basic maintenance...
Previous S2K owner looking at purchasing a nice low mileage 08. The seller has owned it since new and regularly takes it to a local import shop for oil change. Still has the original tires (<25k miles) and has replaced the battery twice. Other than that, nothing! I'm floored that an import shop wouldn't even adhere to the basics in the manual such as rear diff fluid, coolant, brake fluid, MTF, clutch fluid, air filter, cabin air filter, etc. Such an easy money maker for them.
While I'm not shy, in fact I relish the opportunity to get her up to speed, would anyone be leary buying an 11 year old S2000 with low miles without these basics done?
TIA.
Old Jun 1, 2019 | 04:31 AM
Kyle's Avatar
Nope! Buy it
Old Jun 1, 2019 | 04:43 AM
rpg51's Avatar
Nope. Buy it. Replace fluids, Replace tires. Enjoy.
Old Jun 1, 2019 | 08:28 AM
Bri's Avatar
Bri
I agree with the two responses above. Buy it and change the fluids.
Old Jun 1, 2019 | 09:04 AM
cosmomiller's Avatar
Top Answer: 1
Lots of threads on what to do to establish a maintenance "baseline". If you are in the NY area you can have Billman do his special. However it is not really that difficult to do some things yourself. Beside all the fluids (including the swap out over time with the clutch fluid and brake bleed) you can check the torque on the rear axle nuts and since this is a DBW throttle, you should check the valves.
Old Jun 1, 2019 | 10:47 AM
rpg51's Avatar
Definitely check and adjust the valves as soon as you can. Sounds like a nice car.
Old Jun 1, 2019 | 11:41 AM
DesertWanderer's Avatar
TIA.
How about don't buy it but pm me with where it is at?
Old Jun 2, 2019 | 01:45 PM
Jggysk2's Avatar
TIA.
Sweet, nice find. So are you planning to do all the Basic maintenance? Seems it is wortwhile and also uncover potential issues when being worked on.
Let's see the pics when you pick up the ride.
Old Jun 2, 2019 | 02:51 PM
GuthNW's Avatar
The same goes for you of course.
Old Jun 2, 2019 | 04:17 PM
Chuck S's Avatar
The 2006 and later cars have the Maintenance Minder in the dash electronics and it will light up when maintenance is required. There is no other schedule. A very low mileage/time car will only have a few of these and unless cleared start indicating negative mileage and other nags on the dash. Appears these are not appearing. The 2005 owners manual has all the maintenance details. Honda has all the manuals on line. I'd find the first major maintenance and do that. Suggestions are listed previously. Typical unknowing shop (or dealer!) will use the wrong oil filter and differential oil. It's in the owners manual, a small booklet that many don't bother to read...
Valve adjustment of DBW cars is vital based on indications here that they were either set too tight at the factory or got that way during use. Billman posted a Warning a couple of years ago. Excellent device and dirt simple to do. A Honda motorcycle dealer/mechanic probably has more experience/expertise in this task if you don't have time yourself. Engine has to be cold though. Fixing to check mine again in a few weeks. They were fine 20K miles ago.
-- Chuck
