Battery died..
Old Mar 16, 2025 | 11:03 AM
  #31
noodels's Avatar
R.I.P
Old Mar 16, 2025 | 12:59 PM
  #32
cosmomiller's Avatar
Top Answer: 1
When I hit five years for a battery, if I see so much as a slight hiccup, it is gone to be replaced pronto. I don't want to play games with that.
Old Mar 17, 2025 | 07:35 AM
  #33
idea-catalyst's Avatar
The problem is that I don't see a "slight hiccup" because the battery is on a maintenance charger. The charger takes care of the small "drains" from the electronics that never shut off, but, once off the charger, the battery will start the car after 10 minutes, but after an hour the weakness becomes apparent and will no longer start the engine. :-(
Old Mar 17, 2025 | 08:23 AM
  #34
windhund116's Avatar
Read the voltage across the battery terminal with the car at idle and warmed up. It must be above 13.5 volts, or the alternator is not charging the battery.
Old Mar 17, 2025 | 01:28 PM
  #35
Top Answer: 1
If it is fine after maintaining charger but dies in the car, I also see an issue with parasitic drain and or alternator charging issue.
ShirleyTemple
Aug 16, 2014 09:06 AM
megalomaniac
Nov 17, 2012 10:20 AM
danio
Southern Ontario For Sale
Jun 18, 2012 08:10 PM
TRW
Nov 20, 2009 02:40 AM
Picturepro
Jul 1, 2007 11:41 AM
