Battery Relocation Help
I'm assuming this is the breaker I need? And I noticed an in/ out indicator on the breaker.. How do I know which wire goes to in and which to out?
Rockford Fosgate RFCB100 100 Amp Circuit Breaker
I wouldn't solder any of the connections, use high quality crimping instead.
That circuit breaker seems like it could work but I'm not certain that 100A is enough.
IN/OUT shouldn't really matter but I'm guessing battery connects to IN and OUT goes to engine/starter.
If you look at the picture on the package this seems to be confirmed.
There's a thread on here where the guy used a 150amp breaker. I'm trying to understand the purpose of the breaker if there's a 100amp fuse in the fuse box? I hate electric so maybe someone with a better understanding can shed some light
Our starter can easily draw over 400A for the first milliseconds when you push the start button, the stock fuse does not blow though but who knows how that breaker reacts.
Different types of fuses have different characteristic so it's very hard to tell which one will work without any data.
I would use a breaker at whatever the stock fuse is rated for.
