Bent Frame odds
Old Feb 16, 2004 | 02:14 PM
vananron's Avatar
Default Bent Frame odds
Hey, I need to get some expert opinions on the odds that my frame had been bent.
I was going straight at about 55, in the rain, and all off a sudden I caught a puddle, and well, spun about 3 times. Then as I was spinning, I smacked the median, and went up on it, then back down off it. Stalled the car. Then after I got situated, I started the car, and took off, but the steering wheel is off, and the faster I went the car kind of wobbled a bit. I am hoping it is just an alignment being needed, but i'm told it could be a bent frame.
Old Feb 16, 2004 | 02:46 PM
amongmany's Avatar
I'd seriously doubt you bent the frame, but chances are you damaged some suspension parts. I wouldn't drive on it were I you.
Old Feb 16, 2004 | 05:22 PM
CaptinMorgan97's Avatar
check your control arms to see if they are bent or broken. If you macked a curb, 80% of the time the arms will break. I macked a curb going 20mph, spun 2 times and broke the control arms in my right rear suspension. Total cost was +3k. These are made to break taking most of the shock from impact to save our frames.
xviper's Avatar
I don't think a simple alignment will do the trick here.
Old Feb 17, 2004 | 05:41 AM
Squeezer's Avatar
no, there will definitely be some bent suspension parts, plus i'm sure you have damage to the body panels and rims.
Old Feb 17, 2004 | 06:29 AM
vananron's Avatar
I drove it last night back from the shop where I was having some lights installed, and the steering was loose, and it turned right easier than left. It also felt like the car was a little shaky at speeds above 40. But no screeches or weird sounds. But when I pulled in the garage, it had a weird smell, almost like burnt brakes.
Old Feb 17, 2004 | 06:50 AM
Zonie's Avatar
[QUOTE]Originally posted by vananron
Old Feb 17, 2004 | 11:33 AM
vananron's Avatar
I was less than a 1/4 mile from the place with the lights.
thomsbrain
May 11, 2015 09:21 AM
Slowcrash_101
Feb 15, 2015 07:12 PM
Hard Driver
Feb 16, 2009 05:29 AM
Luke530
Oct 8, 2004 07:33 AM
Luke530
Sep 27, 2004 07:58 PM
