Berk Testpipe CEL problem...
Old Sep 22, 2008 | 03:05 PM
Slows2k's Avatar
Get the actual code pulled instead of guessing what may be wrong.
Old Sep 23, 2008 | 05:32 AM
funat9000rpm's Avatar
^^I have had cat issues for the past 2 weeks, either the CEL means broken o2 sensor (I went though 2 in 2 weeks) or it's the fact that I don't have a cat. But I know those could be the only reasons why the CEL came on
Old Sep 23, 2008 | 05:57 AM
Suzuka_Joe's Avatar
I've got a berk on MY02 and havnt had a CEL in the 10,000+ miles i've driven with it
Old Sep 23, 2008 | 01:29 PM
JackS's Avatar
Put a small piece of steel wool above the sensor. I've never had the probem and don't know if this would be a solution or not.' It is reasonable to assume that a disruption of hot gas flow across the sensor COULD solve the problem.
Old Sep 23, 2008 | 02:54 PM
114_ap2's Avatar
i had the same problem with my berk TP
go buy this any problem will be solved,
Old Sep 23, 2008 | 03:26 PM
Slows2k's Avatar
You do realize that without the actual DTC you are guessing what is wrong with the car? Get the DTC # It will look like P0xxx
It is entirely possible the CEL is not related to the Test pipe
Old Sep 23, 2008 | 04:04 PM
EVAN&MONICA's Avatar
^ first diagnose the problem then fix issue
Old Sep 23, 2008 | 05:13 PM
vincewchan's Avatar
Go to your local autozone. They don't let you borrow tool(s) anymore only if they come outside to watch you use it.
Old Sep 23, 2008 | 05:26 PM
s2kVTAK's Avatar
definately get the code cuz like the others said it could very well be that there is something not related to the cat that is throwing the CEL. its free to get autozone to code it and you may even be able to go to your mechanic or just a local one and they will code it for nothing. i have a mechanic that just did it for me cuz i thought autozones was wrong one time. no charge or anything.. definately worth a shot man! no need to spend money on something you may not need!
Old Sep 23, 2008 | 07:42 PM
Kirpich's Avatar
Originally Posted by funat9000rpm,Sep 22 2008, 02:08 PM
^^do u think that'll take care of it??
Yep, it might be just what you're looking for.
bgoetz
Jan 16, 2019 04:10 PM
Jared2709
Jan 18, 2013 02:09 PM
s2000maniac
Aug 8, 2011 02:32 PM
P-CarDriver
Feb 3, 2008 01:24 PM
jack.tsu
Sep 9, 2007 03:57 PM
