best method for bleeding slave
Old Jun 24, 2009 | 08:34 AM
mikegarrison's Avatar
Originally Posted by jtree,Jun 24 2009, 09:30 AM
why would you not tighten down the slave? if there's play in the mounting holes, that could be why your clutch pedal has no resistance until 3/4 of the way down.
Good catch. I didn't notice this, and was assuming he was just doing a normal flush/bleed.
Old Jun 24, 2009 | 12:43 PM
SpitfireS's Avatar
https://www.s2ki.com/forums/index.php?showt...&#entry13211812
In a nut shell: by releasing the piston, then opening the bleeder and pushing the piston back in and the fluid out, you're use the slave as a pump.
With the rear pointed upwards there is the smallest chance of trapped air, in combination with the piston all the way in you pretty much get the "Mother of all slave bleeds"
Old Jun 24, 2009 | 12:56 PM
schuetts's Avatar
[QUOTE=jtree,Jun 24 2009, 08:30 AM] why would you not tighten down the slave?
Old Jun 24, 2009 | 01:02 PM
schuetts's Avatar
Would it be better then to jack the car up from the rear? Thanks for the link, very helpful.
Hopefully i'll get this wrapped up today.
Old Jun 24, 2009 | 01:09 PM
SpitfireS's Avatar
schuetts Posted on Jun 24 2009, 11:02 PM
IMO: the best way to bleed the slave is to remove it from the trans.
Read (and do ) this too:
https://www.s2ki.com/forums/index.php?showtopic=370792
Old Jun 24, 2009 | 02:29 PM
schuetts's Avatar
Thanks SpitfireS. I followed that link & greased everything up. I also bled it with it removed from the trans. like you mentioned and it worked MUCH better than the way I had been doing it. It appears that I've gotten all the air out as there's a solid stream of fluid coming out.
The clutch pedal still has a couple of inches before firming up, but it feels like it did before the slave went bad. Is there anything left to do before I take it off the jacks & test drive it?
Old Jun 24, 2009 | 02:47 PM
tronvex's Avatar
Here is a good link for the clutch bleeding
http://forums.s2kca.com/showthread.php?t=12154
Old Jun 24, 2009 | 04:53 PM
schuetts's Avatar
Just got back from a test drive & it's running great. Thanks for the help everybody!
pghs2kid
Oct 3, 2015 09:20 AM
veehexx
Jul 23, 2010 04:12 AM
rob-2
Feb 5, 2010 11:58 PM
kaiske
Oct 1, 2007 03:57 AM
rwheelz
Jun 4, 2007 10:25 AM
